Old 09-15-2020, 10:21 PM   #21
fordor41
fordor41's Avatar
Default Re: seat belt installation 40 Merc
My '41 fordor had the seat bolted to the frame as far as I can recall.
fordor41 is offline   Reply With Quote
Old 06-06-2021, 07:07 PM   #22
russcc
Very good point about the belts being long enough.
The seats in my '40 coupe cam from the factory bolted to cage nuts in the steel reinforcing supports under the floor. The original bolts were 3/8-24 SAE, Ford grade. When I made a spacer to move the seat back for more leg room, I used 3/8-24 SAE flathead allen screws counter sunk into a 3'4" 6061 aluminum block that runs the length of the seat mount so the seat mount bolted flush over them. The sear mount is bolted into the aluminum block with 3/8-24 SAE G8 hex head head bolts with G8 hardened washers. I believe bolting seat belt into a sheet metal floor pan, even with a large washer may not be the most secure way to do it. I will bolt my belts to the aluminum seat spacer.
russcc is offline   Reply With Quote
Old 06-07-2021, 05:29 AM   #23
51 MERC-CT
51 MERC-CT's Avatar
I believe the consensus is that the seat belt should never be attached to the frame.
In the event of a frame separation from the body of the car, the seat belt becomes a guillotine
Old 06-07-2021, 01:39 PM   #24
1931 flamingo
1931 flamingo's Avatar
When aftermarket seat belts started appearing in the early sixties iI installed them in my 32 5W. My Dad got me 4x4 3/8ths thick steel plates and installed under the rear floor pan. If I decide to put them in my 40 I'll so it the same way.
Paul in CT
Old 06-07-2021, 07:14 PM   #25
paul2748
paul2748's Avatar
That is what I did for my 54 Ford
Paul in CT
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 08-09-2021, 02:15 PM   #26
Clem Clement
Clem Clement's Avatar
YAHOO!!!!!!~!!!
BEAT BELTS INSTALLED!
Bruce Metcalf and I teamed up together to get the job dome right. The Julianos color of dark blue looks fab on the '40MERC. I sat in the back seat awhile and proudly looked over the shine, seat belts and swellness of the Merc. In August of 1956, Daddy passed and the 40MERC moved on. Today, that SAME MERC is rebuilt a with new everything, seat belts and ready for more adventures.
Clem Clement is offline   Reply With Quote
Old 08-09-2021, 03:21 PM   #27
farmertom
farmertom's Avatar
hey Clem,like afew others have said seatbeltsplus. thats what i put in front seat in my '37.i believe they had the best price seems like i got 70 inch. tom.
farmertom is offline   Reply With Quote
Old 08-09-2021, 03:23 PM   #28
farmertom
farmertom's Avatar
Clem, MEASURE THREE TIMES BEFORE ORDERING.TOM.
Old 08-10-2021, 08:38 AM   #29
bobsmanstuff
bobsmanstuff's Avatar
I bought retractors , they keep the outside of the belt from falling out the door.
bobsmanstuff is offline   Reply With Quote
Old 08-10-2021, 09:55 PM   #30
fordor41
fordor41's Avatar
I'm sue if you hit something hard enough to separate the body from the frame, how/
where your seat belt is attached will be your least concern!
Old 08-11-2021, 01:36 AM   #31
V8COOPMAN
V8COOPMAN's Avatar
Whether the body completely separates, or if it only skews sideways more than an inch or four, that already-cinched-tight belt can become lethal. An accident that may otherwise be survivable, would likely have a very unpleasant outcome.....not hard to imagine. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 08-11-2021, 07:03 AM   #32
Clem Clement
I havew retractors to put on.
