Old 12-08-2021, 10:55 AM   #1
Peyton
Default Marvel Carb fuel bowl insert
Curious as to what the spring-loaded device does in the fuel bowl. Will the carb function without it?
Peyton is offline   Reply With Quote
Old 12-08-2021, 11:19 AM   #2
katy
katy's Avatar
Default Re: Marvel Carb fuel bowl insert
Deleted
Old 12-08-2021, 11:45 AM   #3
Peyton
Yes
Old 12-08-2021, 11:53 AM   #4
Bob C
Your Carb doesn't look like a Model A Marvel.
Old 12-08-2021, 12:03 PM   #5
Y-Blockhead
Y-Blockhead's Avatar
Can you post more pictures? I agree with Bob C. Maybe an accelerator pump or ?
Old 12-08-2021, 04:20 PM   #6
Peyton
I would post more but cannot navigate the required album steps. Tried to upload the photos and the system will not take them. I got the first image uploaded but got so angry in the process that I almost gave up at that point. Not user friendly!
I remember installing the carb with the captioned insert in it as a backup carb in the past. It worked okay. Thanks for the interest you have shown me on this.
Old 12-08-2021, 04:42 PM   #7
Y-Blockhead
Peyton, If I can't upload a photo I email it to myself at a smaller size. That usually does the trick. Not hard once you figure it out.
Old 12-08-2021, 04:50 PM   #8
Y-Blockhead
Old 12-08-2021, 04:53 PM   #9
Herb Concord Ca
Agree with Y-blockhead, that is an accelerator pump.
Herb Concord Ca is offline   Reply With Quote
Old 12-08-2021, 05:46 PM   #10
Flathead
Flathead's Avatar
Does your carb look like the picture posted by Y-Blockhead? Your float bowl looks like a different shape.
Flathead is offline   Reply With Quote
Old 12-08-2021, 06:20 PM   #11
Peyton
Yes, it’s an exact match. The Marvel might have been made to fit other car makes with some mods depending on the make. The insert might be an accelerator pump, two my carbs have the device and one doesn’t.
Someone might be more familiar than I with the Marvel. I just love Model A era carbs.
Old 12-08-2021, 10:33 PM   #12
Peyton
See photos of the carburetor in question.
Old 12-08-2021, 10:38 PM   #13
Peyton
The photo thing is scarry to me --- I don't understand all the jargon -- thumbnails and such. In the post preview, the "thumbnail" photos are separate from the message section. Well anyway, it worked.
The carb has a partial Zenith GAV but did work well.
Old 12-08-2021, 10:44 PM   #14
Peyton
The white thing under the carb is a phone to prop it up to prevent glare.
Old 12-09-2021, 07:27 AM   #15
jimvette59
jimvette59's Avatar
Could it be a power valve ?
jimvette59 is offline   Reply With Quote
Old 12-09-2021, 11:54 AM   #16
Peyton
Yes, but I wonder if the carb can function without it.
Old 12-09-2021, 02:02 PM   #17
Y-Blockhead
I wonder if you have a miss match carb, the bottom from another model of Marvel? I don't see any way the accelerator/power valve is actuated.
Old 12-09-2021, 03:30 PM   #18
J Franklin
J Franklin's Avatar
Maybe the hole into the carb by the throttle foot had a plunger/linkage that pushed the valve.
Old 12-09-2021, 05:18 PM   #19
slatgrille
slatgrille's Avatar
That hole is where the gas came pouring out when the float was stuck open on my Marvel....a little 'rap' with a stick on the bowl fixed that problem! I like the size and simplicity of the Marvel.
slatgrille is offline   Reply With Quote
Old 12-09-2021, 05:29 PM   #20
Y-Blockhead
That "hole" is the float bowl vent...
