11-27-2021, 01:54 AM | #1 |
39 Frame- Worn wishbone socket
The front wishbone ball socket on my 39 frame is toast. I was considering using pieces of a Model A two piece socket as a repair. Does anyone sell a patch kit, or is this the suggested fix? Otherwise I'd have to fabricate one and weld it in.
Thanks in advance, this is the BEST place for advice on this old iron!
29 Model A Roadster, 39 Pickup, 50 Custom Tudor, 66 Mustang Fastback, 79 F350, 02 Thunderbird |
11-27-2021, 07:07 AM | #2 |
Re: 39 Frame- Worn wishbone socket
Could you not just use a second lower part as a new upper seat? Bolts in and a couple of decent weld beads would make sure it doesn't move. Slightly longer bolts might be needed.
Can I just check.. You do realise there is a rubber ball used in that location? Mart. Last edited by Mart; 11-27-2021 at 07:12 AM. |
11-27-2021, 11:18 AM | #3 |
Yes, I have purchased another cover and a rubber cover. I was just curious what others say.
11-27-2021, 11:25 AM | #4 |
Can you find one off a junk frame and just replace it? Wouldn’t 35-40 ball socket all be the same?
11-27-2021, 12:02 PM | #5 |
I guess that’s what I’m trying to do. Not many left in the rust belt.
11-27-2021, 12:45 PM | #6 |
11-27-2021, 12:54 PM | #7 |
Don't think the Model A parts will work as they didn't use the rubber ball
like the later Ford's. The aftermarket rubber ball for the Model A's used cast upper and lower metal parts. |
11-27-2021, 01:28 PM | #8 |
I ordered a handful of pieces. I’ll post a photo before and after when it’s fixed.
11-28-2021, 06:07 PM | #9 |
Before Sent from my iPhone using Tapatalk
11-28-2021, 06:08 PM | #10 |
During Sent from my iPhone using Tapatalk
11-28-2021, 06:08 PM | #11 |
Grinding Sent from my iPhone using Tapatalk
11-28-2021, 06:09 PM | #12 |
Done. Sent from my iPhone using Tapatalk
11-28-2021, 06:19 PM | #13 |
Wow. To call that Toast, insults toast. Waiting on some "after" photos.
11-28-2021, 06:36 PM | #14 | |
They are uploaded. Sent from my iPhone using Tapatalk
11-28-2021, 07:50 PM | #15 |
They are not showing up here.
11-28-2021, 07:54 PM | #16 |
I can see them.
11-29-2021, 02:33 AM | #17 |
Pics in post #11 & #12 are the repairs?
11-29-2021, 03:27 AM | #18 |
Something we made-up from some saved scraps & a machined receiver chunk of steel. DD . |
11-29-2021, 11:50 AM | #19 |
V8COOPMAN you are an artist!
11-29-2021, 12:04 PM | #20 |
V8: Your engineering is super nice. Does your repair change the castor angle?
