Old 06-15-2019, 03:05 PM   #1
jhowes
Default Differential Carrier Bearings
Does anyone have a good way of getting the bearings off of the carrier? Jack
jhowes is offline   Reply With Quote
Old 06-15-2019, 03:14 PM   #2
Joe K
Joe K's Avatar
Default Re: Differential Carrier Bearings
Bearing "splitter" sold at Harbor Freight.
https://www.harborfreight.com/bearin...bearing+puller
You'll need to have the carrier "split" and use a "bridge" over the hole in the bearing mount.
I have one here I took off using a sharp chisel - but it messed up the bearing seat slightly - which I can clean up with a file.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
