10-16-2021, 08:01 PM | #1 |
Generator charging revisited
Ok, using a digital voltmeter, set on 20v dc. Wiring disconnected output side of cut out reads 8+ volts. Connecting wiring to cut out to check voltage the volt meter goes bannanas. What is going on
10-16-2021, 08:28 PM | #2 |
Re: Generator charging revisited
The generator can put out 20v and yours goes nutz probably because of the 'dirty' signal. An old analog meter will probably work.
10-16-2021, 08:37 PM | #3 |
Unless you a high quality DVM, like Patrick says use an analog Voltmeter.
10-16-2021, 09:29 PM | #4 |
10-17-2021, 07:21 AM | #5 |
Another option is to add a capacitor across the DVM leads. A condensor normally used for the ignition can be used. If you use another capacitor make sure it is installed correctly. An electronic capacitor will have a negative and positive side. You can just leave it installed if you want because it will eliminate most electrical noise coming out of your generator. You may be able to hide it inside the cutout or you can just install it anywhere, like inside the instrument panel. Just connect the capacitor between the lead coming from the generator to ground.
10-17-2021, 08:47 AM | #6 |
10-17-2021, 10:19 AM | #7 |
Do not run a generator with output connections open. With no load it tries to produce infinite voltage. (And burns out.)
10-17-2021, 10:47 AM | #8 |
10-17-2021, 11:28 AM | #9 |
The DMM will also pick up RFI from the ignition system causing it to go nuts.
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 10-17-2021 at 11:29 AM. Reason: Corrected typo |
10-18-2021, 09:05 AM | #10 | |
If you're trying to check generator voltage out, probe as close to the battery as you can get. It's a great noise filter. |
