Old 04-26-2021, 12:43 PM   #1
1948F-1Pickup
1948F-1Pickup's Avatar
Default Ford Flathead Fan Hub/Pulley custom roller bearing design 1948-52 truck SOLD
City: Rancho Cucamonga
State: CA
Price: $250
SOLD
Ford Flathead V8 Fan Hub/Pulley.... custom roller bearing design but looks OE factory-built. This item uses the wide pulley and fan belt. 8-bolt fans will bolt onto this Art Newland hub design. Photos 4 & 5 show internal components, featuring CNC machined steel bearing housing and 3/8" TIG-welded steel flange plate. CNC machined and heat treated 3/4" Summers Brothers 4140 axle shaft. Assembly rotates on two high quality single row sealed ball bearings. Pretty much bullet-proof. Fully assembled and ready to accept your 8 bolt fan and be bolted onto your engine. Never change the oil in your fan hub again!
1948F-1Pickup is offline   Reply With Quote
Old 05-07-2021, 03:40 PM   #2
1948F-1Pickup
Default Re: Ford Flathead Fan Hub/Pulley custom roller bearing design 1948-52 truck
bttt
Old 05-17-2021, 09:54 AM   #3
1948F-1Pickup
bttt
Old 06-01-2021, 10:56 AM   #4
1948F-1Pickup
Bttt
