Old 01-14-2021, 04:57 PM   #1
700rpm
700rpm's Avatar
Default Trunk lid handle not locking
My trunk lid lock has stopped locking. The key still turns and the handle opens and closes properly, but it doesn’t lock. Is there a DIY fix for this or should I just take it to a locksmith? It is not an original, it’s an older replacement (previous owner).
Ray Horton, Portland, OR
Old 01-14-2021, 07:21 PM   #2
Oldgearz
Default Re: Trunk lid handle not locking
Most likely the small latch that moves horizontally when the key is turned has broken off. No fix for this that I know off. I had same problem. The suppliers do not have replacements in stock and all say wait till June. Some do have the scroll style Cabriolet handle available.
Oldgearz is offline   Reply With Quote
Old 01-14-2021, 08:17 PM   #3
McMimmcs
McMimmcs's Avatar
Try to find an original or a rebuilt. I bought 2 reproductions and neither would lock !
McMimmcs is offline   Reply With Quote
Old 01-17-2021, 08:59 AM   #4
Superhart
Superhart's Avatar
I had a funny thing going on. When I bought my 1930 Coupe the trunk handle was installed with the handle facing down (6 o'clock) and it wouldn't lock. After a bit of time trying to figure it out, I removed the lock and handle and noticed the position of the slots on the lock that the handle tang is supposed to slide into. When I installed the handle facing UP (12 o'clock) the handle now locks easily. Finally I noticed other Coupes with the handle installed facing up so I guess that is the way it's supposed to be done.
Superhart is offline   Reply With Quote
Old 01-17-2021, 12:06 PM   #5
700rpm
700rpm's Avatar
I just ordered a new one from Mike’s.
