Old 07-13-2020, 05:41 PM   #1
Gary WA
Gary WA's Avatar
Default Clutch in Noise
Fellow Model A er called said when he presses clutch in makes a loud machine gun type noise! Any Ideas?
www.whidbeymodelaclub.com
Old 07-13-2020, 06:57 PM   #2
Mulletwagon
Mulletwagon's Avatar
Default Re: Clutch in Noise
Clutch finger may be impacting a shock spring on the disk when the clutch pedal is fully depressed. Might try reducing the clutch pedal free travel.
Mulletwagon is offline   Reply With Quote
Old 07-13-2020, 08:15 PM   #3
Dan/Kzo
Dan/Kzo's Avatar
The back of the clutch finger can also bump the bottom of the inspection cover screw if it is too long or not installed with the lock washer.
Dan/Kzo is offline   Reply With Quote
Old 07-13-2020, 08:58 PM   #4
Jim/GA
Jim/GA's Avatar
Remove the starter motor bolt down closest to the engine block. Look at the end of the bolt. If it is ground smooth and shiny, it is rubbing against the ring gear. Remove the starter to confirm by looking at the ring gear on the flywheel.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 07-14-2020, 10:59 AM   #5
PC/SR
The fingers may be depressing to far and hitting things as noted above. Had the same problem. Increase clutch play from 1" to around 2".
PC/SR is offline   Reply With Quote
Old 07-14-2020, 08:19 PM   #6
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
How much fore and aft movement is there in the crank shaft when you’re stepping on the clutch?
Old 07-14-2020, 09:11 PM   #7
Gary WA
Gary WA's Avatar
Haven't heard back from the individual that called me! So thanks for all the reply's.Will pass on when I hear.
