Old 11-24-2019, 06:58 PM   #1
Gary WA
Gary WA's Avatar
Default CCA Cold Cranking Amps?
What does your battery have for CCA? 6V, I have new one with 540CCA doesn't seem to be enough? Thoughts. Last one had 575 CCA.Motor turning over slower, then nothing? Starter?
www.whidbeymodelaclub.com
Old 11-24-2019, 07:37 PM   #2
gdmn852
gdmn852's Avatar
Default Re: CCA Cold Cranking Amps?
Hello, check your cables and ground if they are too small of gauge ,it increases resistance, and a poor ground will also.CCA equal cold cranking amps higher rating more starting power, in basic terms.
gdmn852 is offline   Reply With Quote
Old 11-24-2019, 07:40 PM   #3
d.
just FYI... the Optima 6v. rates at 800 cold cranking amps...lots of juice for many years, worth the $$.
d. is offline   Reply With Quote
Old 11-24-2019, 07:55 PM   #4
The Master Cylinder
The Master Cylinder's Avatar
I have a Duracell 6v. It has 640 CCA. As mentioned clean your connections.
The Master Cylinder
Enjoying life at the beach in SoCal...
Last edited by The Master Cylinder; 11-25-2019 at 05:47 PM. Reason: Spellin' & Gramma..
The Master Cylinder is offline   Reply With Quote
Old 11-24-2019, 10:06 PM   #5
updraught
updraught's Avatar
Try cleaning the battery terminal clamps. Sometimes they end up with a clear coating inside them. They look OK but aren't.
Then try some large jumper cables from the battery to the block and starter. A %6 difference in battery size doesn't seem much.
updraught is offline   Reply With Quote
Old 11-24-2019, 11:36 PM   #6
mike657894
mike657894's Avatar
my air compressor wouldnt go today I usually use this old half plug half switch outlet by the door it sits by. keeps popping the breaker running too slow wont run for more than 5 seconds. plug the cord into a different better outlet and runs like normal. i need to replace the combo switch/plug.
corrosion start with the battery clamps. do you have an extra ground strap? or clean up the splash pan connection points.
mike657894 is offline   Reply With Quote
Old 11-25-2019, 07:53 AM   #7
ryanheacox
ryanheacox's Avatar
There is also a slim chance that the new battery is just bad. It's happened to me before.
ryanheacox is offline   Reply With Quote
Old 11-25-2019, 09:14 AM   #8
30 Closed Cab PU
Mine is a 535 CCA 6V from a farm supply store, 3 years old, I keep it on a battery tender over the winter, put it on a charger for a few minutes in the spring, and make sure to check the electrolyte with a bulb tester in fall and winter.
Here is an inexpensive battery load tester.
https://www.harborfreight.com/100-am...ter-61747.html
30 Closed Cab PU is offline   Reply With Quote
Old 11-25-2019, 09:23 AM   #9
holdover
I second the HF load tester it is not expensive and works good. I have had one for near 10 years. A volt meter alone will not tell the true story of the state of a battery, the load tester will. In the old days we were able to check the specific gravity, but with sealed batteries that is no longer possible. If a battery does not seem to turn the starter like it should, I test it with the load tester, then I charge it and test it again. As others have said there have been times when a new battery was defective. Between vehicles and farm equipment I have over 20 batteries, the load tester is a great tool.
holdover is offline   Reply With Quote
Old 11-25-2019, 09:28 AM   #10
Curtis in MA
I have a load tester for 12v but will that work on 6v?
Curtis in MA is offline   Reply With Quote
Old 11-25-2019, 11:06 AM   #11
30 Closed Cab PU
Yes, there are markings on the meter for 6 V, and for 12V readings.
Old 11-25-2019, 11:11 AM   #12
30 Closed Cab PU
For $20 is inexpensive. If you know what the voltmeter reading should be, an alternate way is with the ignition off, engage the starter for a 5-10 seconds while monitoring a voltmeter at the battery, and it should not dip below a certain level. Then see what the battery is at when you are done.
If you are like me with poor memory, usually can not remember or find the info - prefer to spend the money on the tester.
Old 11-25-2019, 01:48 PM   #13
Gary WA
Gary WA's Avatar
I have a load tester-Bad Battery- twice. exchanged it same thing Bad Battery! Went to different supplier. Thanks for responses!
Old 11-25-2019, 02:07 PM   #14
1931 flamingo
1931 flamingo's Avatar
CLEAN THE GROUNDS AND THE CABLE ENDS.........................
Paul in CT
Old 11-25-2019, 05:29 PM   #15
Gary WA
Gary WA's Avatar
Did all the above! Battery no good times two. Different source today for new battery working Great! More CCA 670!
Old 11-26-2019, 02:22 AM   #16
updraught
updraught's Avatar
According to the "battery experts" the reason batteries don't last long in today's world is that new cars can have up to 300 computers in them.
That continual parasitic drain kills them, apparently.
However, you have just proved them all wrong. How do you feel?
Old 11-26-2019, 05:21 PM   #17
Gary WA
Gary WA's Avatar
Great!!!!
Old 11-26-2019, 06:40 PM   #18
30 Closed Cab PU
True, my parents had a Buick Lesabre my dad had to put on a maintainer on it all teh time when not in use. They only drove it 1 or 2 times a month and the battery would drain. After replacing the battery 2x under warranty, Dealer GM mechanics told them nothing they could do, told them they had to drive it at least once a week to charge teh battery.
After teh Buick sat for 3 or 4 weeks, but does not explain why some are bad from the store, and will not charge up. Suppose they could have sat on the shelf too long and died.
