Old 11-24-2019, 11:21 AM   #1
Gary WA
Gary WA's Avatar
Default Double Venturi Carb using?
Anyone using a Double Venturi Carb? Do you see any differences from a standard Zenith?
www.whidbeymodelaclub.com
Old 11-24-2019, 11:52 AM   #2
History
History's Avatar
Default Re: Double Venturi Carb using?
Does anyone have a diagram of a double Venturi carb? I'm having trouble getting my head around it.
History is offline   Reply With Quote
Old 11-24-2019, 12:06 PM   #3
Benson
Benson's Avatar
Upper and lower castings are different from later, also secondary well has NO brass well insert.
Idle jet is longer.
Cap and main jet are inline i.e. not staggered.
Photo of venturi here.
https://modelastore.com/index.php?ro...roduct_id=3992
Benson is offline   Reply With Quote
Old 11-24-2019, 01:49 PM   #4
Gary Karr
Gary Karr's Avatar
I have the first generation Zenith double venturi on my ve-28. It runs really smoothly and almost seems to start faster than my Zenith 2 Holleys.
Gary Karr is offline   Reply With Quote
Old 11-24-2019, 02:04 PM   #5
Gary WA
Gary WA's Avatar
Thanks have a couple rebuilt but haven't tried yet
Old 11-26-2019, 12:33 PM   #6
Bob Bidonde
Bob Bidonde's Avatar
The Ford Service Bulletins, Pages 206, 207, 208 & 209 give an excellent description and operation of the Zenith Double Venturi carburetor.
The Secondary Venturi (#10) increases the inlet air velocity at the tips of the Cap and Main Jets. Notice in Figure 420 on Page 206 how high the throat of the Primary Venturi is above the tips of the Cap and Main Jets. The Double Venturi was thought to provide better acceleration.
In September of 1928 another service bulletin was issued describing the change to the Single Venturi Zenith Carburetor (Page 280). Note in Figure 569 on Page 280 that the throat of the new venturi is lowered to about the same position as the double venturi throat. The changes in flow necessitated changing the Main Jet and the Cap Jet orifices.
As for performance, removing the Secondary Venturi from the inlet air passage improves the inlet air flow volume and smooths the flow stream which produces more high speed power than the Double Venturi.
The Venturi in either the Double or Single design has no effect on the idle circuit. In the Single Venturi Zenith, the new Idle Jet, the new Idle Jet Well, the Compensator Jet and the new throttle plate affect idle performance.
Bob Bidonde
Old 11-27-2019, 09:29 AM   #7
al's28/33
al's28/33's Avatar
My double venturi has not let me down in 18 years of ownership. The only fuel issue I had was when I first got the car and had a secondary modern filter on the gas line. It was always in need of cleaning and would starve the carb of gas when I was in the middle of traffic. Removed it and no issues ever since. Keep your cars the way they came off the assembly line.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 11-27-2019, 02:33 PM   #8
ryanheacox
ryanheacox's Avatar
Just a couple
ryanheacox is offline   Reply With Quote
Old 11-29-2019, 09:05 AM   #9
JD 1931
JD 1931's Avatar
I have a early double venturi that I rebuilt and run, it is very nice with all the original parts except a new double venturi and shows no signs of wear or pitting.It preforms well but does not have the top speed as the single. I like the sound of it at idle, can hear the air passing into it....
JD 1931 is offline   Reply With Quote
