Old 09-12-2018, 10:54 AM   #1
Kahuna
Kahuna's Avatar
Default OVERHEAD CAM Model A/B
Last evening my neighbor & friend stopped by with a 32 Ford Roadster on a trailer. A very nice fenderless roadster hot-rod.
It had a Model B block with a dual overhead cam setup. The cams are driven by Gilmer type belts. The casting seemed to be well done, along with the cam covers themselves.
It has a 5 main crank & a 5 main girdle, fully pressurized & maybe dry-sumped
Has 2 Weber carbs on the driver's side.
I saw no name on the head.
It was purchased thru someone's estate in Norcal.
Just wondered if anyone has seen something like this?
The owner said that supposedly 10 of these heads were produced.
Oh, the water pump is remote & fan is electric.
That's about all I can remember.
Regards
Jim
Kahuna is offline   Reply With Quote
Old 09-12-2018, 12:47 PM   #2
Dodge
Default Re: OVERHEAD CAM Model A/B
Sounds like an REM head. A picture would be good. If so Steve Nelson went 201.78 mi.
per hr. at Boneville with one on his car.
Dodge is offline   Reply With Quote
Old 09-12-2018, 01:04 PM   #3
ryanheacox
ryanheacox's Avatar
There's a website with a bunch of pictures of various OHV/OHC Model A/B engines. Can't remember the name right now though.
ryanheacox is offline   Reply With Quote
Old 09-12-2018, 01:11 PM   #4
Tim Ayers
I would love to see it. Sounds awesome.
Old 09-12-2018, 03:47 PM   #5
wensum
wensum's Avatar
If you want to go really fast then I can see the justification of the complex improvements, but surely one of the attractions of the Model A is its simplicity, and one can double the original horsepower with relatively simple improvements whilst retaining the side valve configuration?
wensum is offline   Reply With Quote
Old 09-13-2018, 02:07 PM   #6
Dan McEachern
Here is a picture of the engine in Steve Nelson's #221 Lakester. REM head on a B block.
Dan McEachern is offline   Reply With Quote
Old 09-13-2018, 07:08 PM   #7
Jim Brierley
Steve has gone over 200 MPH in that car, I think it has more than double the original HP.
Jim Brierley is offline   Reply With Quote
Old 09-13-2018, 09:02 PM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Ryan, it's NWVS.ORG
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 09-14-2018, 08:07 AM   #9
ryanheacox
ryanheacox's Avatar
Thanks, Bill!
Old 09-14-2018, 01:47 PM   #10
100IH
There is a speed museum in Nebraska that has nearly everything with a good website. link should be on northwest speedsters site.
100IH is offline   Reply With Quote
Old 09-14-2018, 07:57 PM   #11
Kahuna
Kahuna's Avatar
Yes, Dan
It looked similar to the picture you posted.
Thanks
I once saw a HAL headed engine too
Old 09-15-2018, 03:20 PM   #12
1931 flamingo
1931 flamingo's Avatar
I've wondered what ever happened to all the A's in the 40's, 50's, 60's that had OHV conversions on them...................
Paul in CT
Old 09-15-2018, 07:04 PM   #13
Dodge
Check out the F.A.S.T. Group, ther are a bunch over there. I have two of them.
Old 09-16-2018, 06:17 AM   #14
Kahuna
Kahuna's Avatar
What's a FAST group?
Old 09-16-2018, 08:02 AM   #15
briphaeton
https://www.hotforhotfours.com/
briphaeton is offline   Reply With Quote
Old 09-16-2018, 11:19 AM   #16
Jim Brierley
F.A.S.T. is a group dedicated to performance Model T,A, and B's. www,hotforhotfours.com Performance equipment is still being made, including OHV conversions.
Old 09-16-2018, 11:39 AM   #17
foxfire42
foxfire42's Avatar
F.A.S.T.
Ford A Speed Technology
foxfire42 is offline   Reply With Quote
Old 09-17-2018, 07:19 PM   #18
modelAsteve
modelAsteve's Avatar
We have a F.A.S.T. hill climb in Auburn, CA on October 6th. You just might see one of the cylinder heads you saw in your friends '32. I know you will see lots of very fast A's and go away with a bad case of "BANGER OVERLOAD" Check out our web site for more info. See you there!
modelAsteve is offline   Reply With Quote
Old 09-18-2018, 10:55 AM   #19
Jim Brierley
There will be another F.A.S.T. hill climb in Murietta in Dec. check their website for more info.
Old 09-18-2018, 11:45 AM   #20
California Travieso
Send a message via Yahoo to California Travieso
Jim,
The Flyer says November 4. Are you taking your speedster?
David Serrano
California Travieso is offline   Reply With Quote
