Old 09-09-2017, 05:55 PM   #1
imacrazy
Default white Grease
How would a good white grease work in your steering box?
imacrazy is offline   Reply With Quote
Old 09-09-2017, 06:02 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: white Grease
It won't work in mine, or, any other Model A box as far as I'm concerned.
Old 09-09-2017, 07:01 PM   #3
1931 flamingo
1931 flamingo's Avatar
PennRite steering box lube. No leaky.
Or the 600 the dealers sell.
Paul in CT
Old 09-09-2017, 07:32 PM   #4
Keith True
Keith True's Avatar
I use cotton picker spindle grease,it is $5.per quart at tractor supply.It carries an 00 designation,and if you look at the specs for Penrite it seems to have most of the same ones.It's actually used in a lot of high pressure applications.The pressures between the gears in an A steering box are kind of wimpy compared what farm machinery components go through.I haven't read the bottle in a while,but I seem to remember it lists it's usage for corn heads too.
Keith True is offline   Reply With Quote
Old 09-10-2017, 06:36 AM   #5
aermotor
What's a "corn head"?
John
aermotor is offline   Reply With Quote
Old 09-10-2017, 06:53 AM   #6
Patrick L.
Patrick L.'s Avatar
John
Combine spindle grease.
Old 09-10-2017, 08:38 AM   #7
40 Deluxe
John
It's the attachment on the front of a combine for harvesting corn. It snaps the ears off the stalks and carries them into the combine where the kernels are shelled off the cobs. When harvesting wheat or other small grain, a "grain head" is attached to the combine.
Old 09-10-2017, 09:16 AM   #8
Dino's A
Dino's A's Avatar
I use a little STP in the box to help things slide.
Dino's A is offline   Reply With Quote
Old 09-10-2017, 03:14 PM   #9
steve smith
I use 50% stp and 50% John Deere corn head grease (available at your local J D store for about $4 a tube) in my transmission and rear end and straight corn head grease in the steering box. Also use it in my 6' rotary mower gearbox and anywhere 90+ weight would go. Its very slippery and this stuff doesn't leak out .
steve smith is offline   Reply With Quote
Old 09-10-2017, 03:30 PM   #10
marc hildebrant
marc hildebrant's Avatar
I would suggest what Ford used, namely 600W.
Marc
marc hildebrant is offline   Reply With Quote
