Old 06-15-2017, 11:22 PM   #1
Kahuna
Kahuna's Avatar
Default Ahooga Horn
Guys
I have a 6 Volt Ahooga horn that works real well.
It has no "bell" on the front.
Someone mentioned that it may be a truck horn
from some unknown year Ford?
I would like to use it on my 32 Tudor, but wonder
about acquiring the correct bell for it. I would also
convert it to 12 volts.
Are the bells available from some vendors?
Thanks for your time.
Jim
Kahuna is offline   Reply With Quote
Old 06-15-2017, 11:41 PM   #2
Larry Jenkins
Default Re: Ahooga Horn
Originally Posted by Kahuna View Post
Guys
Jim
Check out A&L
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 06-16-2017, 12:11 AM   #3
Stew Masche
Stew Masche's Avatar
A&L Canton, CT 860-693-0112
M-Th 8-5 Fri 8-12 EST
email [email protected]
Always one bad decision away from a good time.
Stew Masche is offline   Reply With Quote
Old 06-16-2017, 07:26 AM   #4
Joe K
Joe K's Avatar
And you're talking a "double rework" of a horn to make it suitable for your purpose?
Hutchins has resumed making their 1950s era Model A Horn repops. Available in both original 6v and 12v.
http://www.ebay.com/itm/THE-ORIGINAL...ZX4VqK&vxp=mtr
Also available in colors, chromed part or all, or solid black. Even black wrinkle.
I think I paid $3 at a flea market for mine.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 06-16-2017, 10:19 AM   #5
Kahuna
Kahuna's Avatar
Thanks guys
Joe, I don't know much about these horns, but I think this one is
an original horn.
Just thought I'd use what I have, rather than buy a new repro.
Thanks again
Jim
Old 06-16-2017, 12:21 PM   #6
1931 flamingo
1931 flamingo's Avatar
X2 on A&L.
Paul in CT
Old 06-16-2017, 02:02 PM   #7
Joe K
Joe K's Avatar
If an original Model A type horn it could be a Sparton, Ames, E.A, Stewart Warner or G.I.M. brand horn. Parts may be interchangeable, but also may not be.
Currently horn bells are reproduced for Sparton and Ames brand. If you are not sure of your horn manufacture, you could contact a supplier who has the bells and ask them for diameter and bolt circle. You may be able to create a close match.
Think $65 to $75 for the bell plus shipping.
Joe K
Old 06-16-2017, 07:58 PM   #8
Licensed to kill
Licensed to kill's Avatar
My '31 DD came with what I assumed is an original horn. It was strapped to the rad support under the hood and, rather than the flared bell like Joe K posted, the cone is a straight taper and a bit longer. My horn is a Klaxon.
Licensed to kill is offline   Reply With Quote
Old 06-16-2017, 08:19 PM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
Some GM cars of the 20's used a Klaxon horn like you describe.
Old 06-16-2017, 09:50 PM   #10
Kahuna
Kahuna's Avatar
I will look closely to see if I can find a mfg's mark.
Thanks
Jim
Old 06-17-2017, 09:11 AM   #11
insomniacshotrods
insomniacshotrods's Avatar
Macsautoparts has the horn bell
Part #: 28-21303-1
Alt Part #: A13807B OEM Part #: A13807
Price:
$64.95 ea.
Fitment:
1928 thru 31.
They also have 12 to 6 volt reducers but from what I read and bought the one from speedway motors is the best choice. Part # 910-64103 electric reducer for motors. It's gold and bolts on the frame or where you want to put it. Tested great on mine.
Enjoy life , it has an expiration date.
insomniacshotrods is offline   Reply With Quote
Old 06-17-2017, 01:44 PM   #12
pgerhardt
pgerhardt's Avatar
Thanks guys
an original horn.
Thanks again
Jim
If your horn is an original 32 Ahooga it will look like pictures 1 & 2. Notice the motor case is not cylindrical like the model A, and the offset bracket that mounts to the fender not the headlight bar. For later 32 see picture #3 of a 32 "beeper" horn.
pgerhardt is offline   Reply With Quote
Old 06-17-2017, 02:00 PM   #13
Jeff/Illinois
Jeff/Illinois's Avatar
Originally Posted by 1931 flamingo View Post
X2 on A&L.
Paul in CT
Exactly. I am running their Sparton horn and it works/looks absolutely great. Perfect. Boxed up my original which kinda worked, wasn't too bad, and it is parked on the parts shelf.
Jeff/Illinois is offline   Reply With Quote
