Old 07-13-2014, 07:54 PM   #1
grantsauder
grantsauder's Avatar
Default Steering Adjustment
I had to remove the steering assembly from my late 31 CCPU to adjust the steering play which was in excess of 2 inches. It is a two tooth unit. I did all
the adjustments as as instructed in the Model A Ford mechanics Handbook Vol. 1. It mentions the centralization rivet slot is normally set in the vertical position.
Question: What does the adjustment from the vertical position control? more info is needed so as to fine tune the steering assembly.
Thanks for your welcome info. Grant
grantsauder is offline   Reply With Quote
Old 07-13-2014, 08:23 PM   #2
Mitch//pa
Default Re: Steering Adjustment
it centers the worm and sector teeth. it will give you more of a fine tuning on your adjustment...
Old 07-13-2014, 08:34 PM   #3
Mitch//pa
this may you help visualize it
Old 07-19-2014, 05:13 AM   #4
nickair
nickair's Avatar
Two of the easiest things to do to reduce steering play.
1) Tighten your Pittman Arm attachment to steering box shaft. This will make a difference and it is easy. An insignificant amount of play, barely detectable, will make a inch of slop in the wheel. It should be hard tight at the nut and cotter keyed.
2) Tighten your steering box to frame bolts. They must be tight and cotter keyed. Check torque setting.
Simplicity is the ultimate sophistication.
L.D.
I have 40 horses in the garage.
Only feed them when I want to take them out.
31 Model A Tudor 55B
Nick
nickair is offline   Reply With Quote
