Old 05-26-2012, 07:39 PM   #1
48Flyer
48Flyer's Avatar
Question Kingpin HELP!!
I was planning on replacing the kingpins (spindle pivot shaft) on my 51 Mercury today. After removing the old bushings, cleaning the spindles and pressing in the new bushings, I find that the kingpins are .025 bigger than the inside bushing diameter.
This is the first time I have attempted this job on an old Ford or Mercury and am hoping to get some ideas from experinced folks.
What type of fit should the shaft/bushings be? Certainly not a pressed fit as they do pivot.
What can I do now?
Thanks
48Flyer is offline   Reply With Quote
Old 05-26-2012, 07:44 PM   #2
jimvette59
jimvette59's Avatar
Default Re: Kingpin HELP!!
You will need to ream them to a snug fit. Bring them to a machine shop or buy a expensive reamer and do it your self.
jimvette59 is offline   Reply With Quote
Old 05-26-2012, 08:32 PM   #3
48Flyer
48Flyer's Avatar
Anyone know of a reamer that will work? or want to loan out one I can use?
Car is stuck up on jackstands now!
Thanks
Old 05-26-2012, 08:39 PM   #4
Lawrie
Lawrie's Avatar
Best job you will get ,is take the stub axle with new bushes installed and the king pin to an auto machinist and have him hone the bushes to fit.
Lawrie
Old 05-26-2012, 08:47 PM   #5
jimvette59
jimvette59's Avatar
I second that emotion Lawri. Take the spindles and king pins to a auto machine shop and have them fitted. Jim.T.
Old 05-26-2012, 09:04 PM   #6
48Flyer
48Flyer's Avatar
Just found this. Wouldn't this be the correct tool?
http://cgi.ebay.com/ws/eBayISAPI.dll...m=290628289353
Trying to avoid removing the entire stub axle right now
Old 05-26-2012, 09:10 PM   #7
Henry/Kokomo
Henry/Kokomo's Avatar
That appears to be the correct tool. If you have the front end apart - and apparently you do - I'd vote for having the job done by someone who's done it previously. Chances are, you'll not need to install another set of king pins and the cost of the reamer could be put toward paying an experienced machinist. Chances are you'll be happier with the results if you've not used a reamer before. FWIW.
Henry/Kokomo is offline   Reply With Quote
Old 05-27-2012, 01:58 AM   #8
51 MERC-CT
51 MERC-CT's Avatar
Lawrie
Sorry fellas but the king pin bushings on a 51' Merc. are in the spindle supports not the spindles. And are normally reamed on the car.
Old 05-27-2012, 07:30 PM   #9
bbrocksr
Yes, that's the correct tool. Get one and do it yourself. Its not difficult, just go slow and easy and you will have the satisfaction of doing it yourself.
Bill
bbrocksr is offline   Reply With Quote
Old 05-28-2012, 01:16 PM   #10
jmaotto
I can remember back in the day, I used a rat tail file and inserted it through the bushing. Then with the tire and wheel on their side rolled the bushing with the file inserted until the bushing fit the king pin.
jmaotto is offline   Reply With Quote
