Old 03-23-2020, 08:08 AM   #1
motordr
Default 1932 air filter
I’m looking for information on converting an original 1932 air filter to use a modern paper element. Any help appreciated, especially a number for a filter element that will fit either of the two styles of housings. Thanks, Ted
motordr is offline   Reply With Quote
Old 03-23-2020, 08:18 AM   #2
flatheadmurre
flatheadmurre's Avatar
Default Re: 1932 air filter
K&N atleast used to have a selector where you punched in your measurements and got a suggestion for a filter...
And their filters are as good as it gets...
Old 03-23-2020, 08:38 AM   #3
corvette8n
corvette8n's Avatar
I did this to my '41, I gutted the inside(nothing was cut it all came apart by unbending some tabs) so I was left with a top cover and the bottom bowl so to speak. I then cut a piece of sheet metal to fit in the bottom with a hole in the middle. I went to my local NAPA and talked to the guy who knows flathead's and Ford 8N's, he took measurements and looked in a parts book. He then came out with a couple of filters and we tried them until we got one to fit. I have the empty filter package but it's in the trunk of my car in storage so I can't give you the number right now.
Old 03-23-2020, 09:18 AM   #4
tubman
tubman's Avatar
Perhaps too good. I bought a K&N replacement filter for the 327/350 in my Corvette. The engine developed an occasional "hiccup" going down the road. Put the stock filter back on; no "hiccup". Looked both filters over carefully to see if there might be some other factor causing this and couldn't find anything. Put the k&N back on - "hiccup", "hiccup".
I'm now running the stock filter. The only thing I can think of is that, because of it's superior filtration, total flow is reduced to the point of affecting engine performance.
My advice on this would be is to get the largest possible dry filter that you can cram into the original housing. We all know about those little "helmet" thingies being a problem.
Old 03-23-2020, 12:40 PM   #5
estout81
I made my own. Did away with the little "helmet thingies".
estout81 is offline   Reply With Quote
Old 03-23-2020, 02:28 PM   #6
Ronnieroadster
Ronnieroadster's Avatar
Tubman i bet the K&N filter was not restricting the air flow but actually giving the engine more air. More air would then crate a lean situation thus causing the hiccup which was a symptom of a lean backfire in the intake manifold.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 03-23-2020, 02:37 PM   #7
tubman
tubman's Avatar
Nope. No "hiccup" when I ran it with no air filter at all.
I spent a lot of time chasing this, as I had a hard time believing that it was the air filter element causing the problem. I finally got sick and tired of getting nowhere, put the K&N back in the box, installed the stock element, and drove the car.
I will admit I am a bit uncomfortable with the way this ended up, but the problem was solved and I had other fish to fry.
Old 03-23-2020, 03:24 PM   #8
estout81
Ronnieroadster I think you hit the nail on the head. My truck is running lean after I replaced the little helmet air cleaners with my homemade air cleaner.
Old 03-23-2020, 04:25 PM   #9
Ronnieroadster
Certainly unusual for sure but wonder why?
Old 03-23-2020, 04:39 PM   #10
Dave Slater
Dave Slater's Avatar
Try WIX-46641 or NAPA 6641 dry air filters. Dave
Dave Slater is offline   Reply With Quote
Old 03-23-2020, 05:06 PM   #11
Kube
Kube's Avatar
Wow! Interesting indeed. I'd never had thought the filter would have caused the issue.
Old 03-23-2020, 05:41 PM   #12
estout81
Read JWL's book about removing the choke butterfly and shaft on a Stromberg carburetor. Quite interesting!
Old 04-11-2020, 10:56 AM   #13
motordr
Thanks Dave!
