Old 02-03-2018, 03:45 PM   #1
kimeccles
kimeccles's Avatar
Default 1930 Cabriolet front apron question
My front apron under the radiator has 4 screws that go into the sides into long bolts with female ends for screws. This seems normal and I assume the screws are black along with their lock washers.
However on top of where it meets my front fenders there are also 2 holes on each side at the top, yet my front splash guard seems to only have one hole at the very front of it that may attach. The two holes in the back don't seem to do anything? I must have something wrong again and seriously could anything else go wrong??
Dumbest thing I ever did was let someone else dismantle this car who then did not remember what went where...and so I have a box of bolts that I don't even know where they go.
any ideas about the front apron extra bolt holes in the fenders?
thanks.
68B frame# late May1930, fixed seat, Briggs build plate# & most parts, indicate July, or early Aug. 1930.
kimeccles is offline   Reply With Quote
Old 02-03-2018, 05:06 PM   #2
Ed in Maine
Default Re: 1930 Cabriolet front apron question
Is the splash apron a reproduction part? Ed
Old 02-03-2018, 05:18 PM   #3
Larry Jenkins
thanks.
Les Andrews books.
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 02-03-2018, 06:17 PM   #4
jw hash
jw hash's Avatar
yes the four 1/4" fine threaded screws with lock washers are correct and are black the four 1/4-20 oval head screws on top of the fenders, two go down through the frame and the front two go down through the front splash apron and they are painted black also.
jw hash is offline   Reply With Quote
Old 02-03-2018, 07:26 PM   #5
Larry Jenkins
4 side screws oval head with no visible washers?
Old 02-04-2018, 10:10 AM   #6
burner31
burner31's Avatar
Pictures...need pictures.
Easy way for pics:
Click the "blue post reply" lower left bottom of page, when text box opens, in the top middle of the bar you will see a "paperclip" click that, a window will open "manage attachments" click "choose file" then pick your picture, after you picked up to seven pics click the top "upload" on the right hand side of the text box, wait for it to upload.
You must type something, anything into the text box message, scroll down to see "preview post" at bottom of your text box, you should see your message as it will appear when you post, if you like it click "submit reply" to post.
Easy-cheesy
Keith
Shawnee OK
'31 SW 160-B
Old 02-04-2018, 10:16 AM   #7
kimeccles
kimeccles's Avatar
Thanks for the details. Mine is an original part and the info on screw sizes and descriptions was great. Thanks.
Old 02-04-2018, 10:58 AM   #8
burner31
burner31's Avatar
Are these the screws you are talking about?
I left mine shiney because I like they way they look.
Keith
Shawnee OK
'31 SW 160-B
Old 02-10-2018, 11:26 AM   #9
kimeccles
kimeccles's Avatar
Yes. It took a while to get it aligned but it finally went on correctly. Thanks everyone
Old 02-10-2018, 12:57 PM   #10
grantsauder
grantsauder's Avatar
The two holes in the back of the apron are to have a felt riveted to it to provide a noise and vibration between the two parts. See Bratton's #22050. Grant
grantsauder is offline   Reply With Quote
Old 02-10-2018, 01:01 PM   #11
grantsauder
Sorry: It's to prevent noise and vibration between the two parts. Grant
Old 02-11-2018, 05:36 PM   #12
kimeccles
kimeccles's Avatar
grantsauder,
Thanks. Luckily I did use correct felt on the apron even with the right rivet tool before this install. Very good advice to newbies like me.
I seem to have to get stainless bolts to get the right size a lot of times. Then paint black. Seems crazy but so was this idea of an easy restoration....LOL
