Old 05-03-2021, 02:12 PM   #1
hardtimes
hardtimes's Avatar
Default Wire vs lock washers
Ford wired some fasteners.
I like new lock washers.
Any idea why wire originally ?
hardtimes is offline   Reply With Quote
Old 05-03-2021, 02:23 PM   #2
alexiskai
alexiskai's Avatar
Default Re: Wire vs lock washers
One thing that's interesting about safety wire, properly installed, is that the rotation of one fastener that's loosening will pull on the wire in a way that puts tightening torque on the adjacent fasteners. This links the fasteners on a given flange together in a way that lock washers don't.
Old 05-03-2021, 03:05 PM   #3
Oldgearz
Maybe because they didn't have LOCTITE in them days.
Oldgearz is offline   Reply With Quote
Old 05-03-2021, 03:18 PM   #4
jwmckenzie
There are several studies of the effectiveness of lock washers to actually "lock".
Controversial for sure, but NASA says:
“The typical helical spring washer … serves as a spring while the bolt is being tightened.
However, the washer is normally flat by the time the bolt is fully torqued. At this time it is equivalent to a solid flat washer, and its locking ability is nonexistent. In summary, a
lockwasher of this type is useless for locking."
It does serve as a spring to hold the fastener tight if it starts to back out.
jwmckenzie is offline   Reply With Quote
Old 05-03-2021, 05:27 PM   #5
Synchro909
Synchro909's Avatar
I'm sure we have all seen a spring washer gouge a groove under the head of a bolt and into the surface it was against as the bolt is undone. By the time a spring washer is working as it should, the bolt has already lost some of its tension but I wouldn't say they are useless.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 05-03-2021, 10:13 PM   #6
700rpm
700rpm's Avatar
Ford hired the best engineers of his time. I’ll go with their recommendations.
Ray Horton, Portland, OR
Old 05-03-2021, 10:19 PM   #7
CWPASADENA
CWPASADENA's Avatar
Properly installed safety wire is the most positive. There there are places where Henry used wire that I will still use it. I will also use LOCKTITE along with safety wire so I know the fastener will not loosen up, even a little bit.
If I am using lock washers on less important stuff, but I will usually use grade 8 lock washers. They will hold up better than regular lock washers.
Along with grade 8 lock washers (and bolts) such as clutch bolts etc, I will also use LOCKTITE.
My experience,
Chris W.
CWPASADENA is offline   Reply With Quote
Old 05-04-2021, 06:16 AM   #8
chrs1961815
chrs1961815's Avatar
I use safety wire everywhere but maybe on the rear motor mounts because it is so hard to get in there with wire.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 05-04-2021, 06:24 AM   #9
old31
I didn't think that Henry used lock washers. Wasn't it cotter pins and wire only?
Old 05-04-2021, 08:20 AM   #10
wwirz
There is an entire discussion you can have on effectiveness of cotter pins, lockwashers, safety wire, thread lubricants and tightening torque. My experience in the compressor industry is that things like safety wire, cotter pins, lockwashers are redundant to a properly tightened joint based on a certain thread lubricant and clean threads. So an example is: 45 Ft-lbs, clean threads, using Molybdenum di-sulfide thread lubricant. However, you cannot go wrong with how Henry and his engineers designed these cars.
wwirz is offline   Reply With Quote
Old 05-04-2021, 08:52 AM   #11
redmodelt
redmodelt's Avatar
Even by the end of the Model T Ford was migrating away from cotter pins to lock washers in some places. So yes, on the Model A there are cotter pins, lock washers and safety wire depending on location and application.
Old 05-04-2021, 09:12 AM   #12
rotorwrench
rotorwrench's Avatar
Ford mostly used safety wire on bolts that are loaded in tension where the bolted flange is constantly being pushed or pulled on. As was mentioned, a fastener with a wire safety is generally wired in a way as to hold a positive pull on the fastener toward the tighten direction. While it doesn't always prevent them from coming loose, it does prevent them from backing off or turning.
When a fastener becomes loose, it starts fretting and movement in the flange and threaded portions of the fastener. The longer it is loose, the looser it gets until it fails entirely. A wire safetied fastener is proven to stay in place longer than any other form of lock on tension fasteners so it is still in use today but mostly in aerospace and marine applications. In aerospace and marine applications, it is also used on shear type fasteners for applications where constant movement or vibration may cause looseness over time and inspection intervals are infrequent such as in internal components of gearboxes and other enclosed power or drive system components. Fluid systems such as hydraulic, lubrication, or fuel related systems also use a lot of safety wired fasteners and especially where they are critical for safe operation over long periods of time.
Old 05-04-2021, 09:14 AM   #13
GPierce
GPierce's Avatar
Ever wonder why wheel lug nuts, head bolts and nuts have no locking devices?
Here is what we use on aircraft engines. Only use one time and then throw it away and use a new one.
File Type: jpg 6B558CEB-8FB8-4DD5-A970-B6C9187FC605.jpg (24.5 KB, 12 views)
GPierce is offline   Reply With Quote
Old 05-04-2021, 09:44 AM   #14
Bob Bidonde
Bob Bidonde's Avatar
Safety wire, cotter pins, lock washers, Nylock nuts are security devices that prevent the loss of fasteners that become loose. They do not maintain tightness. The safety wire and cotter pin are positive security devices.
Thread locker does retain tightness and it is useless to retain fasteners that become loose.
The friction from torquing and interference fit nuts (AKA self locking nuts) retain tightness. Interference fit nuts also prevent the loss of fasteners that become loose.
Bob Bidonde
Old 05-04-2021, 11:01 AM   #15
Brentwood Bob
What Bob said.
Brentwood Bob is offline   Reply With Quote
Old 05-04-2021, 12:26 PM   #16
Mister Moose
Mister Moose's Avatar
Because the altitude at stall speed of a Model A is zero?
Mister Moose is offline   Reply With Quote
Old 05-04-2021, 02:46 PM   #17
kawagumby
kawagumby's Avatar
Don't forget pal-nuts.
"Thread locker does retain tightness and it is useless to retain fasteners that become loose."
Not true. I've been using locktite on high-vibration dirt bikes for over 50 years...and the material clogs threads enough so it takes effort to unscrew usually even after several turns. I've never lost a fitting with locktite.
kawagumby is offline   Reply With Quote
Old 05-04-2021, 06:07 PM   #18
CWPASADENA
CWPASADENA's Avatar
Henry used both lock washers and safety wire on the rear motor mount bolts. With all the engine vibration, these bolts are hard to keep tight.
I use lock washers, safety wire and LOCKTITE on these bolts and have yet to have one come loose.
The secret with LOCKTITE is to have all the threads absolutely clean.
Chris W.
Old 05-04-2021, 07:36 PM   #19
Stingray70
Stingray70's Avatar
Where is safety wire originally used on the A? I haven't found any on my car yet.
1930 Standard Coupe
Stingray70 is offline   Reply With Quote
Old 05-04-2021, 09:42 PM   #20
kawagumby
kawagumby's Avatar
Engine-wise, safety wire is used with the bolts that hold the flywheel housing to the engine block as well as the flywheel bolts.
