Old 04-29-2020, 08:05 PM   #1
Ratatat
Ratatat's Avatar
Default Is This A Model B Side Cover
Model B side cover?
Thanks
Ratatat is offline   Reply With Quote
Old 04-29-2020, 09:14 PM   #2
chrs1961815
chrs1961815's Avatar
Default Re: Is This A Model B Side Cover
Model B design, yes (no provision for the oil return pipe). But not an original piece, looks made out of aluminum and finned. There was a guy that made valve covers I do believe and I think these might be his?
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 04-29-2020, 09:37 PM   #3
CWPASADENA
CWPASADENA's Avatar
This an aftermarket side cover for a B engine with an OHV head. it covers the intake and exhaust ports in the block.
Chris W
CWPASADENA is offline   Reply With Quote
Old 04-29-2020, 10:00 PM   #4
johnneilson
The fuel pump right below the cover sort of makes it a “B” motor
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 04-29-2020, 10:02 PM   #5
Ratatat
Ratatat's Avatar
Thank you guys. I was asking because I posted another question concerning the serial number on the block which was R4-XXXXXM and where I couldn't find any info with that number letter combination, was getting info that B blocks didn't have serial numbers. So I know for sure it's a B block and it does have a Cragar OHV on it.
Old 04-30-2020, 12:42 PM   #6
Jim Brierley
Use a 1-piece gasket with small slots cut into it for accumulated oil to drain from the stock ports down into the valve chamber, then into the pan. Put something under the engine after removing the pan, it will drip for a long time.
Jim Brierley is offline   Reply With Quote
Old 04-30-2020, 10:33 PM   #7
johnneilson
More importantly what does the rest of the car look like?
John
Old 05-01-2020, 01:09 AM   #8
Ratatat
Ratatat's Avatar
John
1930 Deluxe Roadster
File Type: jpg 9953D108-6299-4057-8918-E816ACE3D1BB.jpg (61.0 KB, 54 views)
Old 05-01-2020, 08:58 AM   #9
johnneilson
Oh Man, that is nice!!
And I'll bet it scoots right down the road, thanks for sharing
J
Old 05-02-2020, 06:00 PM   #10
CWPASADENA
CWPASADENA's Avatar
Very nice,
Chris W.
