10-07-2019, 10:03 AM | #1 |
Miller Overhead
I have an old stock Miller head that I want to put on a full pressure "B" engine for another Speedster I am building. The head came with this 1/8" thick brass or copper spacer or head gasket. Is the purpose of this spacer to decrease the compression or is it supposed to act as a gasket?? I saw somewhere that old racing engines used a solid head gasket. Seems like it might be hard to seal. Any ideas or info on this?
Also, the "B" engine is bored to 4.000". I got a gasket from Bert's that measures 3 7/8" and I have learned since that there is a gasket for cylinder bores up to 4.030". Does anyone know of a source for the larger bore Gasket? The smaller bore gasket will overhang the bore by 1/16" and I am afraid that it will just burn up sticking into the cylinder that much. thanks much for any help. Dick Knapp Last edited by DKnapp; 10-19-2019 at 07:24 PM. Reason: update |
10-07-2019, 10:26 AM | #2 |
Re: Miller Overhead
Have you checked Miller Hi-Speed, they have one for up to 4.030 bore? https://millerhi-speedheads.com/products.html
Bob |
10-07-2019, 10:29 AM | #3 |
Re: Miller Overhead
You need to speak to Joshua Shaw. He is an expert in all things Miller and can set you straight.
10-07-2019, 11:02 AM | #4 |
Re: Miller Overhead
