Old 07-03-2017, 05:50 AM   #21
koates
Default Re: '34 cut-out question
Kerk, Its FUN PROJECTS INC. not FUN PRODUCTS. Regards, Kevin.
koates is offline   Reply With Quote
Old 07-19-2017, 05:47 AM   #22
1934
1934's Avatar
Update; I had my generator checked out at a shop and it's ok. Then I bought a Fun Projects regulator and am very happy! I cruise along and the ammeter shows 2 or 3 amps. With the lights on it still shows a slight charge. This is a really good up-grade and it looks like an original cut-out!
Thanks for your advice, guys!
Doug.
1934 is offline   Reply With Quote
Old 07-19-2017, 10:06 AM   #23
RobR'35
RobR'35's Avatar
Also with our generators. They aren't hard to rebuild or diagnoses problems with.
A book suggested to me by John Regan for this was
"The Model A Generator" by. Paul H. Mcree & William H. Mcree. It applies to all 3 brush gens.
It's a great book to have in our car book libraries.
RobR'35 is offline   Reply With Quote
Old 07-19-2017, 10:12 AM   #24
JSeery
JSeery's Avatar
Great update information.
Old 07-19-2017, 11:23 AM   #25
fourfords
fourfords's Avatar
Sometimes the cut out sticks. I tapped it with a screwdriver handle and it unstuck. If it continues to stick, just replace it.
fourfords is offline   Reply With Quote
Old 07-19-2017, 09:19 PM   #26
koates
1934. If you read the FUN PROJECTS instruction sheet that comes with the regulator it states to set the third brush on your generator at a maximum of 20 amps before installing or connecting the regulator. For an original 1934 Ford 3 brush generator a setting of 15 or 16 amps is high enough and was the original specification and 20 amps is too high. A setting of 15 amps will ensure your generator windings do not overheat especially if you are doing a long run at night with headlights on and the generator working at its maximum third brush setting. It will have a long happy operational life at no more than 15 amps. I have a FUN PROJECTS round voltage reg on my stock 34 Ford and it works very well. Regards, Kevin.
Old 07-20-2017, 04:17 AM   #27
1934
1934's Avatar
Thanks Kevin. Yes, I followed the instructions exactly when I installed it and it's working perfectly!
Doug.
