11-30-2015, 06:55 PM | #1 |
speedometer question
Can anyone tell me how to remove the needle from a '34 Ford speedometer? Thanks in advance.
11-30-2015, 07:19 PM | #2 |
Re: speedometer question
They just pull off.
Lawrie |
11-30-2015, 07:21 PM | #3 |
That was anti-climatic.
12-01-2015, 12:15 AM | #4 |
I'd hold the needle shaft with some needle nose pliers. Don't want to over stress the anything attached to the shaft
12-01-2015, 01:11 AM | #5 |
And I suppose the other question is, how do you get it back on ......in the right place ?
If they are like any other speedo I have worked on, you have to mark the drum before you remove needle. or what is the alternative ? Drive with a GPS and push the needle on at the matching speed ? |
12-01-2015, 06:10 AM | #6 |
Doug. |
12-02-2015, 12:02 AM | #7 |
there is an adjustment to calibrate the speedo. It's a tab attached to the pointer coil spring
but it will not adj. to zero |
12-02-2015, 07:44 AM | #8 |
I put it back together and positioned the pointer at zero when re-installing the needle. It seems to work fine when testing with the cordless drill and speedo cable. Haven't been able to test it in the car yet because it's been raining the last couple of days. Thanks. Doug.
12-02-2015, 10:07 AM | #9 |
In watch repair we have a special tool that directs the force outward when pulling of a typical watch hand.
Thread Tools | |
Display Modes | |
