Old 04-27-2021, 05:37 PM   #1
louieglen
Default Oil drain plug
I bought a car, and decided to change the oil. The grommet? that the drain plug screws into turns with the plug. Is there any thing I can do other than pull the pan? Thanks
louieglen is offline   Reply With Quote
Old 04-27-2021, 08:48 PM   #2
Synchro909
Synchro909's Avatar
Default Re: Oil drain plug
Those bosses are only soldered in. What you describe is not uncommon by any means. I had it happen once when I was 2,500 miles from home. I had to drop the sump to change the oil, then drove home and fixed it.
Resoldering is not so easy now that it is soaked in oil but not impossible. That will only leave you where you were before - a weak joint. I recommend brazing it or welding and yes, the sump has to come off - not that it is a big job.
Old 04-27-2021, 09:00 PM   #3
louieglen
Thanks, That was what I was afraid of. I was hoping someone would have an easy fix. Again Thanks
Old 04-27-2021, 09:21 PM   #4
Mister Moose
Mister Moose's Avatar
Pro tip:
If this happens on the road, before you drop the pan to change the oil, there are several designs of oil suction devices where you can suck it right through the dipstick hole. Rotary pumps on a drill or vacuum based with an air pump on a metal tank. Might be worth the day wait and the FedEx charge to ship one in.
Mister Moose is offline   Reply With Quote
Old 04-27-2021, 11:14 PM   #5
Model A Ron
Model A Ron's Avatar
I would have it welded when you have the time to fix it right. For a quick oil change pick up a vacuum pump. This is what I use on my boat and I think I purchased mine at Walmart.
Ron
Model A Ron is offline   Reply With Quote
Old 04-28-2021, 06:45 AM   #6
Ray64
Ray64's Avatar
There is also a vacuum pull that looks like a grease gun. Just put the hose in and pull the handle. Works great and cheap too.
Ray64 is offline   Reply With Quote
Old 04-28-2021, 07:23 AM   #7
louieglen
Thanks' fellows, I bought a vacuum pump and am going to try it, Again thanks
Old 04-28-2021, 05:24 PM   #8
Synchro909
Synchro909's Avatar
The sump still has to come off to fix it so why?
