Old 11-30-2015, 06:55 PM   #1
1934
1934's Avatar
Default speedometer question
Can anyone tell me how to remove the needle from a '34 Ford speedometer? Thanks in advance.
1934 is offline   Reply With Quote
Old 11-30-2015, 07:19 PM   #2
Lawrie
Lawrie's Avatar
Default Re: speedometer question
They just pull off.
Lawrie
Old 11-30-2015, 07:21 PM   #3
SofaKing
SofaKing's Avatar
That was anti-climatic.
SofaKing is offline   Reply With Quote
Old 12-01-2015, 12:15 AM   #4
fordor41
fordor41's Avatar
I'd hold the needle shaft with some needle nose pliers. Don't want to over stress the anything attached to the shaft
fordor41 is offline   Reply With Quote
Old 12-01-2015, 01:11 AM   #5
pooch
pooch's Avatar
And I suppose the other question is, how do you get it back on ......in the right place ?
If they are like any other speedo I have worked on, you have to mark the drum before you remove needle. or what is the alternative ?
Drive with a GPS and push the needle on at the matching speed ?
pooch is offline   Reply With Quote
Old 12-01-2015, 06:10 AM   #6
1934
1934's Avatar
I managed to get it off ok. Thanks guys.I don't think there will be a problem getting it back on, there's something in behind the face to adjust the needle back to zero.
Doug.
Old 12-02-2015, 12:02 AM   #7
fordor41
fordor41's Avatar
there is an adjustment to calibrate the speedo. It's a tab attached to the pointer coil spring
but it will not adj. to zero
Old 12-02-2015, 07:44 AM   #8
1934
1934's Avatar
I put it back together and positioned the pointer at zero when re-installing the needle. It seems to work fine when testing with the cordless drill and speedo cable. Haven't been able to test it in the car yet because it's been raining the last couple of days. Thanks. Doug.
Old 12-02-2015, 10:07 AM   #9
FrankWest
FrankWest's Avatar
In watch repair we have a special tool that directs the force outward when pulling of a typical watch hand.
FrankWest is offline   Reply With Quote
