11-21-2022, 11:30 AM | #1 |
adj lifters
Since i can't get adj flat head lifters from Johnson where is the next best lifter that i can buy for my build ? Don't want to look for used johnsons.
thanks kurt |
11-21-2022, 11:47 AM | #2 |
Re: adj lifters
I think you can still get the good adjustable lifters, just not the hollow type. There is a company called "Topline"? that made them at least until a couple of years ago. It seems they may have priced themselves out of the business.
11-21-2022, 12:22 PM | #3 |
Re: adj lifters
I used hollow adjustable lifters from Red's Headers in my engine about 6 years ago. I adjusted them once after the engine break-in and haven't touched them since. I have about 6000 miles on the engine.
11-21-2022, 01:25 PM | #4 |
Re: adj lifters
I did a lot of research a few years back as I was unsatisfied with the unpredictable 'interference fit' of offshore lifters. I created a state of the art scientific testing apparatus to measure the breakaway point if thge lifter's capscrew. There was good input from others on the thread I created. Worth looking at. Thread was titled 'Loose in the lifters'.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
11-21-2022, 01:38 PM | #5 |
Re: adj lifters
I'd check with Red's. I bought everything but lifters from him for my 8ba rebuild. Quality parts and fair prices IMO. But then I've never used the lifters he sells.
Making the simple complicated for over 30 years. |
11-21-2022, 02:05 PM | #6 |
Re: adj lifters
11-21-2022, 05:16 PM | #7 |
Re: adj lifters
I've seen an ad on ebay(I think) that claims they are selling new real hollow Johnson adjustable lifters for like $225. Seems fishy.
11-21-2022, 09:32 PM | #8 |
Re: adj lifters
Agreed. That same vendor, I believe, also has some auctions with a starting bid of $1.00 for a set of 16 lifters with no reserve. Seems totally fishy.
11-22-2022, 12:54 AM | #9 |
Re: adj lifters
I recently bought a set of those lifters and while I have not used them yet they pass the file hardness test well. They look like an excellent product. A friend, who is a professional builder has used many of them, but has found a few to be soft.
11-22-2022, 09:20 AM | #10 |
Re: adj lifters
I just received my made in the USA hollow adjustable lifters from Schneider cams . They look and feel like the Johnson lifters from back in the day.
Tim |
11-22-2022, 09:36 AM | #11 |
Re: adj lifters
11-22-2022, 04:29 PM | #12 | |
Re: adj lifters
I just did test with a file and they were as hard as factory non adjustable. They are currently in a 3 3/8 x 4” with just breakin time on it . |
11-22-2022, 04:38 PM | #13 |
Re: adj lifters
11-22-2022, 04:40 PM | #14 |
Re: adj lifters
This is good to hear.
11-22-2022, 06:58 PM | #15 |
Re: adj lifters
I've used the solid adj lifters in many engines with no problem. However I think these were the ford tractor lifters. Passenger engines don't see the RPM's most race engines do. Just adda .060" shim on the valve springs.
Gramps |
11-22-2022, 07:54 PM | #16 |
Re: adj lifters
I got a set from them a few years ago and two of the sixteen were dead soft. Thankfully, I was able to test them prior to installation.
11-22-2022, 11:08 PM | #17 |
Re: adj lifters
where can original johnson lifter be reground?
11-23-2022, 06:22 AM | #18 |
Re: adj lifters
11-23-2022, 09:10 AM | #19 |
Re: adj lifters
If you have a good old set that is properly hardened, I'd much rather spend the money to resurface them than risk using a new unsure set.
Over half the old flathead caracasses I have sitting in my garage have adjustable lifters in them. I surely won't be tossing those lifters as the engines get torn down. |
11-23-2022, 10:51 AM | #20 |
Re: adj lifters
