09-17-2012, 01:03 PM | #1 |
32-34 ford rear shackles
Hi,
It seems like everyone is out of rear shackles for the 32-34 Fords. Does any one know the shackle center to center length? I guess I'm going to have to make some. |
09-17-2012, 01:38 PM | #2 |
Re: 32-34 ford rear shackles
There's no difference between the front and rear shackles.
09-17-2012, 02:09 PM | #3 |
I used Peat & jakes , they last the best if you want to drive it.
09-17-2012, 02:12 PM | #4 |
As far as I know ,On a 33 /34 the shackles are longer on the rear as the rear spring is wider ,I thought this would be the case for 32 as well ?? He can use 35/36 rear ones ,will fit
09-17-2012, 04:39 PM | #5 |
The front are narrower than the rears.
I Got mine from AJAYS ford parts in New zealand,He has nos ones. Lawrie |
09-17-2012, 04:48 PM | #6 |
The shackle bars are same front and rear 32-40. Neal |
09-17-2012, 05:21 PM | #7 |
The shackle studs are, of course, of different length front to rear, but the shackles themselves are the same. The question posed about center-to-center length would seem to pertain to the shackles, not the shackle studs.
09-17-2012, 06:50 PM | #8 |
Thanks everyone. I found a set of nos ones thru the forum. Now I just need some
front spring perches and I'll be set. Dodge |
