08-09-2012, 07:17 PM | #1 |
Ceramic header coating
I recently had a set of flathead headers ceramic coated. The guy who does this as well as all types of powder caoting told me this coating has a degree of thermal insulating property, in other words it keeps some of the exhaust heat in the pipe. I was wondering if coating the exhaust runners in my next flathead would help keep some of the heat out of the cooling water? Rich
08-09-2012, 07:40 PM | #2 |
Re: Ceramic header coating
Rich, You do have a good idea, but you're not the first to have thunk it! Ceramic coating the exhaust chambers in flatmotor blocks is being done, but is expensive. Jet Hot, I seem to remember, charges about $450.
Alan |
08-09-2012, 08:36 PM | #3 |
Ive put reds headers on two engines one 21 stud LB and a 59 AB neither gets to hot! As long as i keep moving.But then I'm in Seattle area.75% today 8-9-12.These headers get the exhaust out and away from the block.Use very little antifreeze down to about 10%.
08-09-2012, 09:19 PM | #4 |
Its really a simple process, the biggest job is prepping the exhault passages. A sandblaster would work just fine, then a solvent wash. After that fluff in the powder, roll it in the oven. Here in florida you could probably just leave it out on your driveway in the sun for a few hours Rich
08-12-2012, 01:14 PM | #5 |
After much pressure they finally installed full exhaust collecter rings on the engines and additional upholstry that was extra thick. It helpes some, but they were still a noisey airlane al |
