Old 04-11-2021, 02:16 PM   #1
bautiprea
Default grey smoke out of exhaust - hill/slope
Hello forum! I have recently noticed that when the car is on a slight hill, or slope stationary(for example when entering my house which has a slight upward slope) grey/dark smoke comes out of the exhaust, and idle seems to be rough/slower than usual. Is this normal or should I check for something?
Cheers
bautiprea is offline   Reply With Quote
Old 04-11-2021, 02:26 PM   #2
Ruth
Default Re: grey smoke out of exhaust - hill/slope
Cheers
You may check your float level. It may be a little too high causing the engine to flood going up hill. does this occur when going up other hills? Or are you on relatively flat ground?
Ruth
Old 04-11-2021, 03:34 PM   #3
bautiprea
I noticed it at first when parking momentarily on my entrance, but recently I had to stop on a light in an underpass(U shaped train underpass) which was really steep, and noticed idle was extremely low and rough, and saw smoke on my rear. While waiting for the light, i played with GAV to see if it made a difference and it really didnt.
Old 04-11-2021, 03:52 PM   #4
Ruth
Your GAV shouldn't have much if any effect at idle. Try adjusting your idle mixture screw.
Ruth
Old 04-12-2021, 02:05 PM   #5
Patrick L.
Patrick L.'s Avatar
A grey/blue smoke is generally the sign of oil.
Old 04-12-2021, 02:34 PM   #6
Benson
Benson's Avatar
1. Also you get Blue/Grey smoke when the Beautician at the Nursing Home burns the hair clippings!
Benson is offline   Reply With Quote
Old 04-12-2021, 07:38 PM   #7
Model A Ron
Model A Ron's Avatar
Check your compression
Model A Ron is offline   Reply With Quote
Old 04-13-2021, 07:54 AM   #8
Big hammer
What would a cloud of brown smoke be? Not in an A but a ford t-bird mid 60's. I was told it hasn't run so good in awhile, oh yes some tire smoke also, my guess a rust clogged exhaust, teenager's!!!
get a bigger hammer tap done
Thread Tools
Display Modes
