04-05-2021, 12:16 PM | #1 |
39 ford waterpumps
Iam replacing the 2 water pumps they are attached to the motor mounts after taking off the nuts i was hoping the pumps would come off they wont pull off will i have too raise the motor a bit or is their some other way to get them off i dont want to pry to hard i am afraid they will break any suggestions on this THANKS JIM S.
04-05-2021, 12:20 PM | #2 |
Re: 39 ford waterpumps
Don't forget the bolt hidden in the water outlet.
04-05-2021, 12:37 PM | #3 |
Yes , as solidaxle said . Theres a bolt in the hose port .
04-05-2021, 12:42 PM | #4 |
i got that bolt also still wont come off my question is do i have to raise the motor in order to get the pumps off. THANKS JIM S.
04-05-2021, 12:50 PM | #5 |
I thought I found them all but took your advice and did a double check and found the hidden bolt and got it off! Thanks so much!
04-05-2021, 01:49 PM | #6 |
Alan |
04-05-2021, 01:57 PM | #7 |
You do need to support the engine as the water pumps are the engine mounts.
04-05-2021, 03:45 PM | #8 |
I wonder how many pumps were chiseled off and damaged because of that hidden bolt.
04-05-2021, 04:07 PM | #9 |
I tried to remove mine without knowing about the hidden bolt, I stopped myself just short of prying it and waited till I pulled the engine, then spotted it....
Sometimes, ingenuity gets in the way of sense and sanity. |
04-05-2021, 04:11 PM | #10 |
Anti seize and a stainless bolt for the bolt inside the housing. Some will say no to the stainless bolt but I was taught by one of the best IMO so stainless it is.
Making the simple complicated for over 30 years. |
04-05-2021, 04:21 PM | #11 |
04-06-2021, 06:55 PM | #12 |
Anti-seize is the key for any stainless hardware. Stainless likes to gall when coming apart so the anti-seize is a must. It's even worse with dissimilar metals than it is for stainless on stainless fastener joints.
04-06-2021, 07:04 PM | #13 |
I have found just the opposite. The only case I had with galling was when I used a stainless bolt and stainless nut. Used quite a few stainless bolts in dissimilar metals and never had a problem - including using stainless bolts on exhaust headers or manifolds. No anti-seize
04-07-2021, 07:57 AM | #14 |
Dissimilar metal corrosion is a real thing and should not be discounted and especially where moisture is in the mix. After 40-years in the aviation industry, my experience has been different.
