Old 03-10-2021, 04:30 AM   #1
48fordnut
48fordnut's Avatar
Default Fan belt
I need a part number for a fan belt for a 5/8 wide belt. 39 48 ford single belt configuration.
Thanks,
jim
48fordnut is offline   Reply With Quote
Old 03-10-2021, 04:50 AM   #2
Kerk
Default Re: Fan belt
I think the number I have used is "B54 .. This is from memory which is not getting better with age!! kx
Kerk is offline   Reply With Quote
Old 03-10-2021, 05:32 AM   #3
48fordnut
48fordnut's Avatar
Thanks.
jim
Old 03-10-2021, 07:10 AM   #4
Mart
Mart's Avatar
It depends on which intake manifold you have.
On my coupe I use a B50
On the 32 I have a B51. The manifold makes the generator sit a bit higher.
Old 03-10-2021, 08:02 AM   #5
jimvette59
jimvette59's Avatar
If you want to measure the length of the belt you need lay electrical tape carefully around the outside of your pulleys. Be careful not to stretch the tape. Then lay it out on a flat surface and measure the length. The B will determine the with and angle. Just my way. I hope this helps.
jimvette59 is offline   Reply With Quote
Old 03-10-2021, 09:05 AM   #6
Mart
Mart's Avatar
^^ It's not quite as simple as that. There is about a 3" difference between the circumference and the belt number size.
I found a mention of it here, for example.
https://www.biedlers-belts.com/gates-b52-belt.html
Old 03-10-2021, 09:29 AM   #7
marko39
B(size)+ 3"= true length . With an A belt the difference is 2". I use a cogged belt which is a BX belt made for tight radius.
marko39 is offline   Reply With Quote
Old 03-10-2021, 01:20 PM   #8
solidaxle
solidaxle's Avatar
Buy a couple sizes smaller and larger then you think you need. Then bring the unused ones back. It will save running back and forth to the auto store.
solidaxle is offline   Reply With Quote
Old 03-10-2021, 03:10 PM   #9
48fordnut
48fordnut's Avatar
the b numbers are NAPA. I have a B 59 and it is about 6 -7 '' too large. One more trip.
thanks for all the replies.
jim
Old 03-11-2021, 09:03 AM   #10
jimvette59
jimvette59's Avatar
Thank you for that information but I have never had trouble doing it my way. JMHO
Old 03-11-2021, 10:33 AM   #11
51woodie
51woodie's Avatar
Jim. The belt that drives the pumps and generator on my '46 Coupe, 59AB, is a Gates TR24530.
51woodie is offline   Reply With Quote
Old 03-11-2021, 11:34 AM   #12
48fordnut
48fordnut's Avatar
Thank you 51.
Thanks to all for the education. As I have gotten older , I don't remember things I should.
Jim
Old 03-12-2021, 01:06 PM   #13
RalphG
RalphG's Avatar
Its a little late but I just read the number on the fan belt of my 39 deluxe. Its likely 50 years old but might still be some use. Its a Gates Vulco 643 Made in Canada B4. Thats exactly how it reads off the back of the belt.
RalphG is offline   Reply With Quote
Old 03-12-2021, 01:44 PM   #14
G.M.
For fan belts go to Paulbhardware.com They are on Woods Corner rd.
in Lititiz,Pa. They have a section of ceiling about 60 feet by 125 feet
with thousands of belts hanging. There are plain belts, inner cog, outer
cog, cloth covered. The "B' belts have a tapper that matches the 30's
and 40's pulley tapper. They have them all listed on their website. G.MC
www.fordcollector.com
