Old 01-27-2021, 03:37 PM   #1
aandkt
Default 1936 Rumble Seat Lower Clips
I need some pictures or ideas on how to mount a LOWER rumble backrest to my '36 rumble lid. I need lower clips or a picture of what they look like so I can make them.
Any Ideas,
Thanks
aandkt is offline   Reply With Quote
Old 01-27-2021, 04:00 PM   #2
Terry,OH
Terry,OH's Avatar
Default Re: 1936 Rumble Seat Lower Clips
Check the deck lid to see if you have the two "D" nuts at the lower sides of the backrest in the deck lid.
Old 01-27-2021, 04:12 PM   #3
wamnram
wamnram's Avatar
Go to Mac's website and search on "Rumble Seat Clips" and you will see what the upper and lower clips look like. The lower clips are an "L" shaped strap that are held by screws in the D-nuts mentioned above. You slide the rumble spring frame down into the clips.
Wayne
wamnram is offline   Reply With Quote
Old 01-27-2021, 05:03 PM   #4
Steve in Denver
Steve in Denver's Avatar
Are you talking about the Rumble Seat hinge Bump Stop? If so, Drake has them and they fit right in the existing holes.
Oh, you will need the hook too to support the seat back springs.
If you want to build a rain gutter like an original one, I can tell you about that off line. I duplicated the one Grant has in his original '36 rumble seat, thanks again Grant.
Steve in Denver
Steve in Denver is offline   Reply With Quote
