Old 10-18-2020, 08:56 AM   #1
tudor87
Default Rear “C pillar” 31 Tudor
Help, I have to rebuild the bottom of a severely rusted bottom of both of the rear pillars of my 31 Tudor. I would greatly appreciate a picture (profile and straight on) of one. Or a sketch with measurement for The holes. Thank you, Gary
tudor87 is offline   Reply With Quote
Old 10-18-2020, 04:03 PM   #2
Mike Peters
Mike Peters's Avatar
Default Re: Rear “C pillar” 31 Tudor
I don't know what a C pillar is on a Tudor. If the door hinge post is the A pillar, the door latching post the B pillar, then where is the C pillar?
Mike Peters is offline   Reply With Quote
Old 10-18-2020, 09:00 PM   #3
tudor87
I didn’t know what else to call the post/pillar on the Tudor sedan. It is the one that defines the back part of the rear quarter panel window. As a matter of fact the window channel is attached to it. If it is known by another name please let me know. The bottom is attached to the subrail by 3 rivets but mine are completely rusted away. Either I will try Berts or fabricate the bottom part myself. Thank you
Old 10-19-2020, 04:14 AM   #4
shew01
shew01's Avatar
Can you post a picture?
shew01 is offline   Reply With Quote
Old 10-20-2020, 02:35 AM   #5
tudor87
I’m going to try and post picture, not always successful.
Old 10-20-2020, 03:40 AM   #6
tudor87
83D2FF6F-4FBD-408E-9F3F-B1EA6AE165C6.jpeg Picture of quarter panel brace/pillar?
Old 10-20-2020, 02:48 PM   #7
Mike Peters
OK, now we the problem. Since that area will be covered by the back seat, I would weld/fabricate the base of your C-pillar and rivet to the subframe.
Old 10-20-2020, 03:01 PM   #8
tudor87
Mike, thank you for the input. Even if I were to get a picture of the bottom area it would be a problem to manufacture anything close to the original.
Old 10-20-2020, 06:15 PM   #9
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Send me your email through a PM, and I will e-mail you pictures and dimensions of what you are missing.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 10-22-2020, 09:48 PM   #10
tudor87
Thank you so much for your help. I sent you an email with my needs. The biggest thing I need is a good picture of what the bottom of the brace that runs from the the roof thru the wheel well to the subrail looks like. I would like to rebuild mine, if I can. Also I need exact measurements on where it will mount to the subrail. Mine is rusted out completely.
