09-09-2020, 10:39 PM | #1 |
Tank sealer
Guys I need to seal a gas tank or glue it on my small Poulan chainsaw. Recommendations please! Thank you
09-09-2020, 11:27 PM | #2 |
Re: Tank sealer
Epoxy?
09-09-2020, 11:35 PM | #3 |
Re: Tank sealer
Just what would seal it inside or weld it on the outside.
09-10-2020, 12:40 AM | #4 |
Re: Tank sealer
What caused it? Puncture? Rust?
We speaking of a nylon type tank ? U say weld...steel? Replace it....nothing will work well Likely new replacement tank not available? |
09-10-2020, 12:40 AM | #5 |
Re: Tank sealer
Order a new one, or try the 2 part epoxy.
09-10-2020, 07:10 AM | #6 |
Re: Tank sealer
09-10-2020, 08:56 AM | #7 |
Re: Tank sealer
If it is plastic you cam melt it with a soldering iron and build up the hole just like you would welding up a hole.
09-10-2020, 09:48 AM | #8 |
Re: Tank sealer
Tried all of these solutions nothing works, you’ll end up getting a new tank or sorry to say scrap it.
09-10-2020, 10:38 AM | #9 |
Re: Tank sealer
If the tank has deteriorated from the use of gasohol you'll have to replace it w/a new gasohol resistant tank.
Bindar Dundat
09-10-2020, 02:54 PM | #10 |
Re: Tank sealer
I've heard good things about this product.
Not cheap, that's for sure. I have not used it. Good luck. https://www.ebay.com/itm/CASWELL-EPO...53.m1438.l2649 .
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!" |
09-10-2020, 04:24 PM | #11 |
Re: Tank sealer
There is no replacement available from what I can find out. When I said weld, there is such a thing as plastic welding now that is done on newer cars. For instance the bumper. I don’t know what caused it. Seems to have just started. It is inside a metal cover and there is now way something could have punctured it. It may be a nylon tank, to Métis plastic. Any ideas
09-10-2020, 04:25 PM | #12 |
Re: Tank sealer
Ronn the gas tank is on a Poulan micro xxv. Been a very good little saw . And has plenty of power now for its small size.
09-10-2020, 04:27 PM | #13 |
Re: Tank sealer
dbaldwi3 that’s what I’m afraid of, having to scrap it. Runs good for its size and age. I’ve had it a really long time. I’m the first owner.
09-10-2020, 04:35 PM | #14 |
Re: Tank sealer
1930-Pickup, thanks for the link. $52. dollars is sizeable but it’s my choice. I just hate to give up using it when it runs so good. Looked on eBay, no luck. ronn said he might have one, hope so. Thanks for all responses.
09-10-2020, 07:52 PM | #15 |
Re: Tank sealer
If you do use that tank sealer, please let us know the results. I was thinking of using it as a fuel resistant connection sealer.
09-11-2020, 06:29 AM | #16 |
Re: Tank sealer
I dont have that one. Might also want to check out Hirsch gas tank sealer. they use it on planes..... I have had great success with it, but dont know regarding plastic. It does seal holes.
Thread Tools | |
Display Modes | |
