06-25-2020, 07:53 PM | #1 |
luggage rack
Hello to all.
I was looking for some info about putting a luggage rack on my 31 Victoria Does it need to have any special brackets for it to fit with the spare on the there? I have a fellow who is selling one and he says the instructions say it's only for the 2 door sedan and the touring. Thanks for any help. Stay safe, PaulB |
06-26-2020, 08:09 AM | #2 |
Re: luggage rack
My luggage rack fits both my 28 Coupe and 29 Tudor as they are the same spacing and bolt pattern. However, when the rack is on the 28 Coupe, I could not remove the spare tire as it rode too low and the rack interfered. No issues on the 29 Tudor.
06-26-2020, 09:13 AM | #3 |
Re: luggage rack
With spare on 30 Coupe needed to install bracket extensions, to clear tire.
There are brackets that are thicker , so if a heavy load in trunk go for more robust ones. Bob F |
06-26-2020, 09:25 AM | #4 |
Re: luggage rack
On my 4 door I opted for the extensions and I still cannot get the spare tire off without removing the rack. One of the guys in the club added about 2" and then it worked. But they need to be really beefed up thickness wise due to the trunk being out so far. I am going to use the 29 version as I think it sits further out normally. I have the aftermarket chrome version right now.
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
06-26-2020, 10:24 AM | #5 |
Re: luggage rack
Mac's has the only luggage rack I have seen listed specifically for the Victoria. https://www.macsautoparts.com/ford_m...-victoria.html You may need the extenders to clear the spare tire. Sorry, the link does not seem to be working. Rack part #28-22144-1, heavy duty extenders part #28-857767-1
I don't know what the deference of the racks are between the different Model A models (Sedan, coupe, Vicky) except for maybe the slant of the back. To me a trunk looks out of place on a coupe, sort of hangs out in space. Last edited by Y-Blockhead; 06-26-2020 at 10:39 AM. |
06-26-2020, 10:31 AM | #6 |
Re: luggage rack
06-26-2020, 11:08 AM | #7 |
Re: luggage rack
Here is how it was done on a prior owned SW sedan. The added diag .braces were made from emt conduit to help support the extra oversized trunk weight.
06-26-2020, 12:52 PM | #8 |
Re: luggage rack
I like the extra bracing. I went another route the rubber mounted the trunk to my spare. I may add the braces, sometimes I have some weight in the trunk.
06-26-2020, 01:04 PM | #9 |
Re: luggage rack
Paul
With your Victoria's rear mounted spare, you will need the trunk rack extension brackets. See Bratton's #25171. There are special brackets for a Victoria with side mount spare tires. See picture of my Victoria's original trunk rack mounting bracket.
Bill Cilker, Jr Unrestored 190A Victoria 45B, 160B & 189A Victoria Association President |
06-26-2020, 07:39 PM | #10 |
Re: luggage rack
Thank you all for taking the time to answer and help me.
You are a great bunch and this site has to be one of the best. You have given me a lot of info to work with. Thanks again,PaulB |
06-27-2020, 09:56 AM | #11 |
Re: luggage rack
These are the brackets I have on my 190A:
Bob Bidonde |
