06-06-2020, 04:18 PM | #1 |
Catseye gas gauge
Anyone else have one of these?
Wow that sucker came out way huge. (Smaller now) Last edited by Badpuppy; 06-08-2020 at 02:56 PM. |
06-06-2020, 04:20 PM | #2 |
Re: Catseye gas gauge
Post a picture of what you have?
06-06-2020, 04:23 PM | #3 |
There's a picture, use scroll bar at the bottom of your screen.
06-06-2020, 04:27 PM | #4 |
Reason I ask is there's not much info to be found. Gasket kits are a force-fit. Faceplate won't go in at all.
06-06-2020, 04:32 PM | #5 |
No picture, just "?".
Ruth "Sometimes you really DO need to read the whole thread" |
06-06-2020, 04:36 PM | #6 |
06-06-2020, 04:39 PM | #7 |
06-06-2020, 04:45 PM | #8 |
I dont see know stinkin picture.
06-06-2020, 04:53 PM | #9 |
My Sport Coupe has one of these lenses. I had no issues with assembly using cork gaskets.
06-07-2020, 08:21 AM | #10 |
No picture here on iPhone either.
06-07-2020, 09:51 AM | #11 | |
https://www.mafca.com/downloads/Semi...20Controls.pdf Gas Gauge Openings Oct 27 - May 28 - Vertical oval opening, flat lens Apr 28 - Sep 29 - Horizontal oval opening, magnifying/flat lens May 29 Oct 29 - Round opening, raised flat lens Nov 29 - End - Round opening, flat lens Gas Gauge History Early gauge until May 28 Vertical oval opening with flat lens • Nickel plated steel casting April 28 redesigned Aluminum die casting • Nickel plated on exposed face - not used after June 28 magnifying glass lens with horizontal oval opening May 29 round gauge opening introduced Initially round glass had flat raised center Changed by Nov 29 to flat glass Your own gas gauge.pdf shows it but I lost the url. |
06-07-2020, 09:54 AM | #12 |
06-07-2020, 10:01 AM | #13 |
06-07-2020, 10:17 AM | #14 |
Thanks, Pluck. Fig. 14 is it. My faceplate is missing the paint, and turned around, apparently. Glass is amber.
The alignment tab on the new faceplate is twice as wide as the original. The drilling is too far inward for the second gasket to fit between it and the lens. Just FYI. |
06-07-2020, 10:33 AM | #15 | |
Copy the picture to your Desktop. Open the picture so it displays on your screen. On top toolbar click on Edit. Depending on what program is being used to open the picture, you may see Resize - click on it. If you do not see resize click on edit again and resize should be there. |
06-07-2020, 11:23 AM | #16 |
Is the glass amber or is the amber from gasoline stain. may have an original in my gas gauge junk box. ken
06-07-2020, 12:01 PM | #17 |
06-07-2020, 12:24 PM | #18 |
Cropped the image, but wouldn't upload here
06-07-2020, 12:44 PM | #19 |
Hope it shows up now. Last edited by Badpuppy; 06-08-2020 at 02:53 PM. |
06-07-2020, 01:04 PM | #20 |
Send it to some one and have them post it.
Not me...I have one hell of a time doing it myself! I have never seen an "amber" lense but that does not mean Ford did not make them. Pluck |
