Old 02-20-2020, 02:17 PM   #1
Werner
Werner's Avatar
Default Good tool to lubricate the leaf springs
Hallo und guten Tag
Here is a perfect tool to spread the layers of the leaf spring so that it can be easy lubricated!
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 02-20-2020, 03:40 PM   #2
wmws
Default Re: Good tool to lubricate the leaf springs
Neat tool. I never saw one like that before.
wmws is offline   Reply With Quote
Old 02-20-2020, 04:07 PM   #3
dbaldwi3
dbaldwi3's Avatar
Is that made from an old c clamp?
dbaldwi3 is offline   Reply With Quote
Old 02-20-2020, 04:38 PM   #4
Werner
Werner's Avatar
It is an original US made tool. Shootet on Ebay.
Werner
Citroen 11 CV, 1947
Old 02-20-2020, 07:21 PM   #5
Chris Haynes
Chris Haynes's Avatar
Here is one I bought on eBay. They appear often. With type the grease gun attaches to the spreader and injects the grease into the spring.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 02-20-2020, 10:18 PM   #6
shew01
shew01's Avatar
What was your search phrase on eBay?
shew01 is offline   Reply With Quote
Old 02-20-2020, 10:49 PM   #7
norcalal
Bought new front spring. What is the best way to lube before I install? Man spricht Deutsch.
norcalal is offline   Reply With Quote
Old 02-20-2020, 11:30 PM   #8
Bill G
Bill G's Avatar
Ditto, with a question mark ??
Bill G is offline   Reply With Quote
Old 02-20-2020, 11:45 PM   #9
alexiskai
alexiskai's Avatar
Werner's tool is called a Knowlson spring spreader. They show up on eBay occasionally, I think there's two up now. There's a similar tool called a tomahawk spring spreader that actually integrated a tube of grease into the tool handle. These are often associated more with Model Ts.
I should note that you can also get excellent results with a pair of flathead screwdrivers and a hammer. Here's a thread I started last year regarding this operation:
https://www.fordbarn.com/forum/showthread.php?t=268039
Old 02-21-2020, 04:42 AM   #10
Werner
Werner's Avatar
Guten Morgen Ford-Liebhaber.
Frau auch? Die neuen Federblaetter habe ich mit MoS2-Gleitlack beschichtet.
I coated the new spring leaves with MoS2 lubricating varnish (OKS 521). It is very important that the surfaces are degreased very carefully. Each layer of paint must be hard dried before the next layer is sprayed on.
I didn't spray the above showed old front spring with grease, but with anti-corrosion wax (Fuchs Anticorit BW 366).
Werner
Citroen 11 CV, 1947
Old 02-21-2020, 08:45 PM   #11
norcalal
Pm sent
