Old 02-12-2020, 07:30 PM   #1
old31
Default Teflon EZ Steer Kit what do you think?
I have everything apart, so I was thinking of installing the ez steer kit, but I am unsure.
What are your thoughts on this product. Have you used it? Did it help? Did it not make a difference? Worth the money?
https://www.snydersantiqueauto.com/P...earchByKeyword
Old 02-12-2020, 07:38 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Teflon EZ Steer Kit what do you think?
Look here - https://www.fordbarn.com/forum/showthread.php?t=276647
Old 02-12-2020, 08:08 PM   #3
whirnot
whirnot's Avatar
I didn't see much difference. But the shortened pitman made a big difference.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 02-12-2020, 08:27 PM   #4
CarlG
CarlG's Avatar
I use them.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-12-2020, 08:29 PM   #5
Y-Blockhead
Y-Blockhead's Avatar
I installed the teflon kit. Didn't make a real big difference but helped some. Ensure your balls are round...
Like Bill said, the shorter pitman arm made a big difference.
Old 02-12-2020, 08:43 PM   #6
midgetracer
midgetracer's Avatar
I put them in one of my pickups. I did not notice much difference
midgetracer is offline   Reply With Quote
Old 02-12-2020, 09:45 PM   #7
updraught
updraught's Avatar
Is it just me, or is this item tricky to find in Snyder's on line cattle dog?
Down the left, not under steering, not under front axle. A search of steering, Model A ... not there.
A search of "steer" brings it up.
Haven't seen the steel ones listed yet, or the bronze impregnated ones.
Are the bronze ones better?
updraught is offline   Reply With Quote
Old 02-13-2020, 12:03 AM   #8
J Franklin
J Franklin's Avatar
I've never seen bronze ones, but they may work nicely.
Old 02-13-2020, 12:54 AM   #9
updraught
updraught's Avatar
https://www.ecklers.com/model-a-ford...8-22435-1.html
Expensive.
Old 02-13-2020, 07:58 AM   #10
ryanheacox
ryanheacox's Avatar
https://www.mikes-afordable.com/product/A3305M.html
Here they are about $20 cheaper. Says they are longer wearing compared to the other teflon seats. I am planning to use the regular teflon when I redo my front end.
ryanheacox is offline   Reply With Quote
Old 02-13-2020, 09:17 AM   #11
alexiskai
alexiskai's Avatar
I used the bronze ones. Figured I only wanted to rebuild the darn thing once. Less resistance than steel, but no different from the regular teflon in terms of performance.
Old 02-13-2020, 09:58 AM   #12
Bob Bidonde
Bob Bidonde's Avatar
I question the longevity of the Teflon ball socket parts. How many miles before replacement?
Perhaps a grease with a Teflon additive is just as good and much less expensive?
Bob Bidonde
Old 02-13-2020, 10:04 AM   #13
tmiller6
tmiller6's Avatar
I’ve been using the Teflon-bronze kit from Mike’s in Georgia. Their current price is $73.25 and I have installed them on three of my cars.
I have them on my slant window sedan and I kept the pitman arm stock. I’m happy with the steering.
tmiller6 is offline   Reply With Quote
Old 02-13-2020, 10:05 AM   #14
rocket1
I would think if the inserts themselves were available it would be more affordable and I probably would give it a go.
rocket1 is offline   Reply With Quote
Old 02-13-2020, 10:13 AM   #15
alexiskai
alexiskai's Avatar
That would be these:
https://www.snydersantiqueauto.com/P...S-ONLY-8-PIECE
Old 02-13-2020, 10:32 AM   #16
ryanheacox
ryanheacox's Avatar
You will need the correct plugs to use those inserts though. Can't use the stock ones.
Old 02-13-2020, 10:42 AM   #17
alexiskai
alexiskai's Avatar
Ah good point
Old 02-13-2020, 11:50 AM   #18
duke36
Use PTFE grease, not lithium or sodium based for the teflon seats.
duke36 is offline   Reply With Quote
Old 02-14-2020, 12:07 PM   #19
redmodelt
redmodelt's Avatar
And too repeat, no amount of fancy material will compensated for steering arm balls that are too worn.
Old 02-14-2020, 06:31 PM   #20
miff
I have then on my two cars plus I had the ball ends replaced . Also have the pitman arm shorten .have had no problems with them . Getting ready to build a husker style delivery and plan to do the same .
miff is offline   Reply With Quote
