Old 12-30-2019, 08:38 AM   #1
svmsr1044
Default Spin on oil filter for Y-block
Were any Y-blocks factory built for “spin on” oil filters?
Thanks,
Steve
svmsr1044 is offline   Reply With Quote
Old 12-30-2019, 09:06 AM   #2
darrell
Default Re: Spin on oil filter for Y-block
no.
darrell is offline   Reply With Quote
Old 12-30-2019, 09:16 AM   #3
KULTULZ
KULTULZ's Avatar
Post Re: Spin on oil filter for Y-block
Yes -
1957/ , but not on all models or trucks
- DISCLAIMER -
The above posted information is in my opinion only (IMO) and may contain copy and paste material(s).
In addition, any above tech information is supplied in good faith. No responsibility implied or otherwise can be accepted for the way others use or interpret provided data.
Your experience(s), opinion(s) and mileage may vary.
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 12-30-2019, 09:18 AM   #4
darrell
they were not built for a spin on filter .an adapter was used.
Old 12-30-2019, 09:30 AM   #5
KULTULZ
KULTULZ's Avatar
They came factory assembly with the adapter and spin-on filter. The adapter was installed 1957/ or offered as an over-the counter kit.
EDIT -
Should read factory assembly came with assembly parts to use SPIN-ON filter. The assembly parts were then released in kit form (although the individual service parts could be bought separately) for prior 1957 assembly retro-fit.
File Type: jpg Oil Filter - ROTUNDA Deco - 1958-1963.jpg (34.0 KB, 12 views)
- DISCLAIMER -
Old 12-30-2019, 06:10 PM   #6
Daves55Sedan
Daves55Sedan's Avatar
Somebody at a Ford dealer told me back in the '70's that the spin-on version was made available in 1957.
But I can tell you this; I must have a really old one, because it is stamped of at least 16 gage or heavier metal. You'd need to swing a hammer pretty hard to make a dent in this one. The newer conversion plates are thin and you gotta be real careful installing them.
Daves55Sedan is offline   Reply With Quote
Old 12-30-2019, 08:40 PM   #7
paul2748
paul2748's Avatar
Starting in 1957, as the others said, spin on filters were original equipment. On cars and Tbirds, trucks???
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 12-30-2019, 10:02 PM   #8
KULTULZ
KULTULZ's Avatar
Not TRUCK until 1963. They could be retro-fitted with the adapter kit.
File Type: jpg Oil Filter - FoMoCo Deco - R1-A - B7A 6731-A.jpg (7.1 KB, 4 views)
- DISCLAIMER -
Old 12-31-2019, 01:31 AM   #9
slumlord44
The kit was orginally a Ford tractor part.
slumlord44 is offline   Reply With Quote
Old 12-31-2019, 10:39 AM   #10
KULTULZ
KULTULZ's Avatar
Please explain.
The kit also fitted some tractor engines.
- DISCLAIMER -
Old 12-31-2019, 10:43 AM   #11
40 Deluxe
What year tractor? Spin-on filters were OEM on 1957 cars..
Old 12-31-2019, 09:44 PM   #12
slumlord44
I'm thinking '54-'55. I rember buying them in the early '60's for a '56 Ford I had.
Thread Tools
Display Modes
