10-18-2019, 03:10 PM | #1 |
Carb Question
I disassembled my Holley 94 carb and I noticed that the Pump Discharge Nozzle has a ball at the end of one nozzle and not at the end of the other nozzle. Is this normal?? thanks in advance
10-18-2019, 03:20 PM | #2 |
Re: Carb Question
Accelerator pump? There is one ball below the nozzle assembly.
10-18-2019, 03:23 PM | #3 |
Re: Carb Question
No, the "pump discharge nozzle", shaped like a "Y"
10-18-2019, 04:59 PM | #4 |
Re: Carb Question
That ball appearing end of the pump nozzle may be just a cap to close the end of the nozzle. The nozzle bars are on both sides of the pump discharge nozzle.
10-18-2019, 05:54 PM | #5 |
Re: Carb Question
Like Terry,OH said, it's probably just a different plug on one side. The nozzle holes are drilled on a downward angle before the end plugs. As long as it squirts out of both holes and not out the end plugs, it's good.
Sal |
10-18-2019, 06:05 PM | #6 |
Re: Carb Question
10-18-2019, 06:08 PM | #7 |
Re: Carb Question
That's what I'm used to seeing. The end caps are small recessed caps. I guess it's possible someone plugged one with a ball on one side.
Sal |
10-18-2019, 08:00 PM | #8 |
Re: Carb Question
That makes sense, I’ll bet that’s exactly what happened.
Thanks all Steve |
