Old 07-07-2017, 01:09 PM   #1
mountinpie
mountinpie's Avatar
Default Radiator Splash Shield Fitment
All,
In order to get the holes in the front fender to align with the splash shield holes, it seems like the splash shield doesn't fit the inside line of the fender correctly. Any thoughts? Thanks!
mountinpie is offline   Reply With Quote
Old 07-07-2017, 04:06 PM   #2
Kevin in NJ
Default Re: Radiator Splash Shield Fitment
Hard to be 100% sure with these pictures, but I think your fenders are not set up properly. Looks like the that forword point is push towards the center and up.
How does your light bar fit with no fenders on the braces?
You can find hints on setting up the fenders in the link to my website below.
Kevin in NJ is offline   Reply With Quote
Old 07-07-2017, 04:55 PM   #3
d.
sideways photos are difficult to read, not helping your inquiry.
d. is offline   Reply With Quote
Old 07-07-2017, 08:44 PM   #4
mountinpie
mountinpie's Avatar
Sorry guys, can't understand why my pics are rotated.
I'll check the fit of the light bar tomorrow. It seems like the fender matches up well with most of the shield except for the forward point.
Old 07-07-2017, 08:54 PM   #5
SeaSlugs
SeaSlugs's Avatar
are these original parts?
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 07-07-2017, 09:06 PM   #6
mountinpie
mountinpie's Avatar
Yes, as far as I know everything is original. The holes on the fenders line up perfectly with the frame and everything else looks good, just seems like the holes in the shield won't line up correctly.
Old 07-07-2017, 09:17 PM   #7
RawhideKid
I am wondering, are the holes in the shield too far forward, or too far back to line up?
Before Walmart you had to buy a ticket to the fair to see a bearded lady!
RawhideKid is offline   Reply With Quote
Old 07-07-2017, 09:22 PM   #8
SeaSlugs
SeaSlugs's Avatar
somethings wonky... can you get a pic of the inner part of the fender where the hood latches are? like have the pic show where its meeting with the splash apron and down the side where the hood latches go...something looks too wide/ not wide enough - not sure if its the fenders or the splash apron...
Old 07-07-2017, 09:29 PM   #9
mountinpie
mountinpie's Avatar
Seems like the holes are too close together which spreads the front point. I'll do some fiddling tomorrow and get better pics to share.
Old 07-07-2017, 09:46 PM   #10
RawhideKid
Ya know what I would do, and this applies to every place with multiple screws to fit, loosen all the screws on the hood sills and fender and see how that lines up.
Old 07-07-2017, 09:59 PM   #11
Larry Jenkins
Originally Posted by mountinpie View Post
All,
A long time ago, I realized that you should keep associated fasteners somewhat loose to allow final fitting to prevent situations like yours.
If you tighten fasteners that will be attached to other parts, you may experience hole alignment problems.
Take front fenders. Count the many places they attach to other parts. Rawhide Kid talks about this..
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 07-07-2017, 10:10 PM   #12
1955cj5
1955cj5's Avatar
Just want to mention that the later 30-31 splash aprons are different from the earlier 28-29 aprons....
What year is the car?
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 07-08-2017, 07:05 AM   #13
KGBnut
KGBnut's Avatar
I rotated your images for you. I thought it would be helpful.
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 07-08-2017, 07:59 AM   #14
mountinpie
mountinpie's Avatar
Thanks Ken, I appreciate that. I did some additional checking this morning.
This is a '30 Tudor. All fender bolts are loose and the light bar fits good. I ran a straight edge along the fender and it looks good, not so with the shield. I also measured about 1-1/4" from the fender bolt hole to the edge of the fender. On the shield that dimension is less than 1". Understanding that the shield needs some work, I don't see how I can make up that 1/4".
Old 07-08-2017, 08:01 AM   #15
mountinpie
mountinpie's Avatar
Some additional photos...
Old 07-08-2017, 09:05 AM   #16
Tom Wesenberg
Tom Wesenberg's Avatar
I can't tell in the 3rd picture, but original aprons are convex on the side panels, while repro ones are flat.
Old 07-08-2017, 09:31 AM   #17
mountinpie
mountinpie's Avatar
Thanks Tom, they do have a slight curve to them, but I'm wondering if I should ty to pick up a better one, maybe in Gettysburg. If not, any recommendations for a good repro? Thanks again.
Old 07-08-2017, 09:48 AM   #18
aermotor
The back of the splash pan should be flat and the corners at a 90 degree angle. Get that squared away and I think you will get the extra length you need on the side panels.
John
aermotor is offline   Reply With Quote
Old 07-08-2017, 02:18 PM   #19
mountinpie
mountinpie's Avatar
Maybe I didn't explain correctly, but it's not the length of the sides, it's the hole placement.
Old 07-08-2017, 02:23 PM   #20
jw hash
jw hash's Avatar
try and original apron. that looks to me as an inexpensive reproduction and most of them do NOT fit, with out some work.
jw hash is offline   Reply With Quote
