Old 10-31-2013, 09:12 PM   #1
tudor87
Default Rebuilding Shocks
I am pretty technically competent and want to try to rebuild my model A shocks. What manual or web site has the best printed directions on the subject? Thanks for the help. Gary
tudor87 is offline   Reply With Quote
Old 10-31-2013, 09:24 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Rebuilding Shocks
Have you looked in the Ford service bulletins?
Old 10-31-2013, 10:06 PM   #3
huddy
huddy's Avatar
Diablo As have a good video on this (available from the usual suspects) which has nearly served to convince me I want no part of doing this. (Maybe it was the part about cooking them for four hours in a charcoal BBQ). They look like a real SOB to disassemble.
Also if you do a search on this forum you'll learn a ton about shocks. The part that concerns me is the high probability that after all that effort to get them apart, they will not be rebuildable. There's also the possibility that welding & machining will be required to get the fixed vanes set up right. Probably I'm going to send 6-8 of them to an expert and see if he can produce a set of 4 rebuilt ones in return.
Owning an antique car is "start fixing one thing, find four other things that need fixing." Lather, rinse, repeat.
huddy is offline   Reply With Quote
Old 11-01-2013, 12:13 AM   #4
Mike V. Florida
Mike V. Florida's Avatar
Here is some info on rebuilding shocks;
http://www.geocities.ws/MotorCity/Garage/1205/hreb.html
Old 11-01-2013, 02:31 PM   #5
mhsprecher
mhsprecher's Avatar
Les Andrews book Vol. 1 has a section on rebuilding shocks, too. It sounds a bit daunting to me.
mhsprecher is offline   Reply With Quote
