04-24-2014, 05:07 PM | #1 |
converter
Im looking for a 6-12 voltage converter like to draw 4 amps threw it . Any idea were to get one for $150 or less
04-24-2014, 07:59 PM | #2 |
Re: converter
Assuming you want to convert 6 volt positive ground to 12 volt negative ground, check out eBay item: 360912320550
It will supply up to 5 amps and costs $60 + shipping. |
04-25-2014, 01:36 AM | #3 |
Re: converter
That converter not quite big enough im darwing 4.6 amps 55 watt. I saw a bigger one at a small vender site But i didnt put it in my favorites now cant find him Bill
04-25-2014, 04:54 AM | #4 |
Re: converter
Hi Bill, Just asking what are you trying to power up on 12 volts that draws 4.6 amps ? Your 6 volt system will have a current draw of approx. 9 amps if you require a step up converter to supply a CONTINIOUS 4.6 amps at 12 volts. I have a couple of good converters from Cruising Electronics, who are in New Zealand. They are rated at up to 7 amps output at 12 volts. Cost about US $100.00. Google them for info. All these converters are designed to power electronic items such as radios, cd players, GPS units, cell phone chargers etc and are not for use on items that have larger electric motors inside like cooling fans, wipers and such. Regards, Kevin.
04-25-2014, 08:44 AM | #5 |
Re: converter
Try [email protected] He has been making heavy duty 6 to 12 volt converters for a long time. I have 2 for 5 or 6 years and they do the job. He has a website but I don't know the address. He posted on here years ago. Or maybe it was on the EFV8 site? G.M.
www.fordcollector.com |
04-25-2014, 08:57 AM | #6 |
Re: converter
Mark |
04-25-2014, 09:34 AM | #7 | |
Re: converter
Martin. |
04-25-2014, 04:45 PM | #8 |
Re: converter
You're right Martin, I should have read that more carefully, Sorry.
Mark |
04-25-2014, 08:10 PM | #9 |
Re: converter
I'm trying to power 12 elect cooler our club is going on a 8 day tour thru eastern Wash into Idaho on into Montana back to Spokane Wash and on Home-- Tacoma
04-26-2014, 09:48 AM | #10 |
Re: converter
I have one 6V to 12V rated at 4.7A and is fused for 6A I will sell for $60.00. It is made by Antique Automotive Radio in Palm Harbor, Fl. They sell for $99.95 new. If you would like mine check with Antique Automotive Radio to be sure it will work for you. I converted my car to 12V
