Old 03-22-2021, 08:58 AM   #1
old Tom
Default securing generator
I have tightened the bolt at the bottom of the generator as tight as I can but the generator will loosen on the belt after a few minutes of running. Am I missing something? there is no bracket that goes between the gen and the motor as this is on other engines.
Thank you
old Tom is offline   Reply With Quote
Old 03-22-2021, 09:07 AM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: securing generator
There is no other bracket. I wonder if you're bottoming out and if an extra washer would help.
There is an after market bracket that may help, but, I've not used one.
Old 03-22-2021, 09:09 AM   #3
Badpuppy
Here's one -
https://www.ebay.com/itm/1928-1929-1...-/124387984925
Old 03-22-2021, 09:25 AM   #4
rocket1
Originally Posted by old tom View Post
i have tightened the bolt at the bottom of the generator as tight as i can but the generator will loosen on the belt after a few minutes of running. Am i missing something? There is no bracket that goes between the gen and the motor as this is on other engines.
Thank you
the bracket is easily fabricated and i cemented a thick piece of rubber to it where it contacts the generator to preserve the paint,works great.
rocket1 is offline   Reply With Quote
Old 03-22-2021, 10:13 AM   #5
Jacksonlll
Jacksonlll's Avatar
You should not run the belt very tight anyway.
Old 03-22-2021, 11:53 AM   #6
Big hammer
That's a difficult bolt/nut to get tight, is it a fine thread or course thread
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 03-22-2021, 12:03 PM   #7
redmodelt
redmodelt's Avatar
As I recall it is fine thread. RE the post above about not getting the belt too tight. Correct. Too tight will cause water pump bushing/bearing to wear/fail faster and maybe, like the radiator, is finding its own level of tightness. If it don't squeal or slip maybe ok were it's at, so maybe a little loose is better then too tight.
Old 03-22-2021, 02:27 PM   #8
J Franklin
J Franklin's Avatar
If your ammeter says it's charging, your belt is tight enough.
Old 03-22-2021, 02:59 PM   #9
Kurt in NJ
Kurt in NJ's Avatar
I used to have that problem, took off all the paint on that area of the front cover and generator
It is one of the few items on the owner instruction book in bold, do not tighten belt unless it slips, translation-- it will look too loose , but it's ok unless it's slipping
Old 03-22-2021, 06:17 PM   #10
Synchro909
Synchro909's Avatar
I've seen even water pumps modified to have ball bearings in the front destroyed by the belt being too tight. The vee shape of the belt means it doesn't have to be tight to drive. The greater the load, the more tension on it and the more it grips.
I have at least 2 inches of free in and out movement of the belt at the RHS of the engine before I feel any tension at all.
Over tightening the belt is probably one of the most common errors made by Model A owners.
There's an idea for a new thread!
Back to the OP's generator not holding adjustment. I have made an arm that goes from the top of the gen to one of the timing cover bolts to secure it.
Old 03-22-2021, 06:30 PM   #11
Gene F
Gene F's Avatar
I have a bit of slack in my belt. When I had a powerhouse gen I went to the hardware store and bought an internally toothed washer to ho under the head of the bolt, and one under the nut. Then I used a breaker bar. I suppose you could break the bolt if you got carried away. Now I have the Ford gen, and I use the little tension bracket that Snyders sells.
I have tried the rubber chunk between the generator housing and the engine block, with some success.
Old 03-23-2021, 08:54 AM   #12
old Tom
Many thanks to all who replied
Old 03-23-2021, 04:47 PM   #13
Gene F
Gene F's Avatar
By the way, always put the bolt in from the back, and the nut near the radiator. If you do it the other way, after your car is together you get to take the radiator out every time you want to move, or remove the generator. Just one of those handy little things to think about...
Old 03-23-2021, 09:13 PM   #14
JDakota
Put a lock washer on before the nut and the belt will stay where you want it!
JDakota is offline   Reply With Quote
