Old 03-05-2012, 07:16 PM   #21
texas webb
Default Re: T-5 flathead question
Originally Posted by Richard in Florida View Post
If you use a T5 with Ford input shaft and a Ford bolt pattern, life gets easier in a hurry. You can use the stock pilot bearing or bushing, the stock throwout bearing and all the clutch linkage, the stock flywheel and pressure plate. All you have to buy is a clutch disk with the same spline as the T5 input shaft. All you need then is a simple flat adapter plate. Any machine shop can make you one.
Richard do you mean using a ford t-5 vs one from an s-10? I'm still learing,thanx.
texas webb is offline   Reply With Quote
Old 03-05-2012, 08:00 PM   #22
donald1950
Default T5 question for richard
richard, is your shifter at the rear of the tailhousing (like mustang and camero) or did they use an S10 tailhousing with the shifter just behind the rear of the main trans case when you had it built? in other words, a ford main transmission case with a chev S10 tailhousing?
donald1950 is offline   Reply With Quote
Old 03-05-2012, 08:03 PM   #23
bobscogin
Most folks use the S-10 T5 because it has the best shifter position for early Fords. Of course, the S-10 tailshaft housing can be installed on the Ford T5, but many would just rather use the S-10 and be done with it.
Bob
bobscogin is offline   Reply With Quote
Old 03-05-2012, 08:06 PM   #24
Ol' Ron
Ol' Ron's Avatar
Richar will have to fill in the facts, but GM went to the Ford bolt pattern a while back, so the shifter is in the right place for most applications. He did however change the gears to Ford.
The ford case adapts to the 8BA bell housing with the pictured adapter.
Old 03-05-2012, 08:22 PM   #25
quickchange34
quickchange34's Avatar
Richard you are right, if you use the ford life is real easy. I have made a few.
quickchange34 is offline   Reply With Quote
Old 03-05-2012, 08:38 PM   #26
jan bogert
jan bogert's Avatar
Texas Webb here is a photo in mock-up. but the arm for the throw-out bearing you position to 4:00/4:30 to have enough throw.i made the mistake and welded it at that pos. also the arm is from my model a. and make the m/cyl. push arm off the bottom of the brake pedal short like mine. because ther's math involved. that piece is the stock one off the model a pedal, from the mechanical brakes. hope this helps. JAN. if i can help just email me.
jan bogert is offline   Reply With Quote
Old 03-05-2012, 08:51 PM   #27
texas webb
Thanx Jan.I see what you meant in earlier post.Ron I have a merc 8CM guessing the same bellhousing,so no need for truck bell&hogshead?
Old 03-05-2012, 08:51 PM   #28
Richard in Florida
Richard in Florida's Avatar
Originally Posted by texas webb View Post
Richard do you mean using a Ford T5 vs one from an S10? I'm still learning,thanx.
Not necessarily. One of the beautiful things about T5s is that virtually any main case can be bolted to virtually any tail section. This is how I ended up with the absolute ideal transmission in my '53 Victoria.
After a great deal of research and investigation I learned that the location of the shifter on an S10 T5 would put the stick WAY forward in my '53. This would call for a long stick, and this would mean a long throw between gears with the stick moving vertically almost as much as it moved horizontally. Very awkward and
not at all cool.
At the other extreme, a Mustang or Camaro T5 would put the stick nearly under the edge of the front seat. Also no good. What to do...
Then I discovered the T5 used in Chevy Astro Vans; this tail section had the shifter about halfway between those of the other two boxes. It seemed ideal, and it is.
I'm lucky enough to have just a few miles from me one the world's premier remanufacturers of T5s... Astro Performance. They specialize in race-strong versions of the T5 and other Tremec boxes. I explained what I was trying to do and about the shifter locations, and they did the rest.
They started with an Astro Van main case that had a Ford bolt pattern, put in a Ford input shaft, installed a gear set with the coveted 2.95 first gear and a .72 5th gear, put a GM output shaft in the tail section to make yoke selection easy, and topped it off with a shifter from an S10 to replace to weird Mickey Mouse offset Astro Van shifter.
I ended up with a virtually brand-new T5 with new bearings, mostly new gears, new synchros, new seals, and so forth. Much better than an unknown quantity from a friend or junkyard.
There are million more details, and I'm happy to share them, but that's my basic story. I am thoroughly enjoying my T5.
Richard in Florida is offline   Reply With Quote
Old 03-05-2012, 08:58 PM   #29
texas webb
Richard,thanx for all that info.I may call upon you for more when I get to that stage.I've also enjoyed your research in fuel economy.Thanx again,Webb.
Old 03-05-2012, 09:01 PM   #30
bobscogin
The S10/S15 went to a World Class Ford bolt pattern T5 sometime during the '93 model year and used it through '95, so it's a relatively rare transmission compared to the Chevy pattern version. That change was concurrent with the '93 model year (4th gen.) F body GM cars which also received the WC Ford pattern T5. Those, however, have the shifter all the way back on the tailshaft housing.
Bob
Old 03-05-2012, 09:13 PM   #31
Richard in Florida
Richard, thanx for all that info. I may call upon you for more when I get to that stage. I've also enjoyed your research in fuel economy. Thanx again, Webb.
There are several other important considerations, such as:
• Thickness of the adapter plate - one size does NOT fit all!
• And maybe THE MOST IMPORTANT thing is concentricity --- making sure the center of the crankshaft is exactly in line with the input shaft of the T5.
• Rear transmission mount. I was able to reverse and modify the original factor trans mount.
• Speedometer accuracy. This could be a seminar in itself. I have extra driven gears left over from my experiments. The calculators only get you close.
• Yoke for the driveshaft.
• New driveshaft. Almost inespacable.
• Using the CORRECT fluid: Dex/Merc III. NOT IV!
• And lots more.
Old 03-05-2012, 09:41 PM   #32
butchbov
butchbov's Avatar
Here's a link to my pictures. feel free to browse, it's all public. http://smg.photobucket.com/albums/v6.../T5%20Install/
I started with a 88 S10 nonWC trans, but have since swapped it out for a 93 S10 WC trans with a 88 S10 tailshaft.
Butch
In a world filled with stress it is better to give than to receive.
butchbov is offline   Reply With Quote
Old 03-05-2012, 10:00 PM   #33
Richard in Florida
Default A Couple of Pictures
Here are a few shots showing the adapter between the transmission and the bellhousing, and the finished shifter in the cabin.
