Old 10-21-2021, 04:30 PM   #1
KenBolton
Default Removing Brake Hose
The hose readily comes loose from the cylinder but am having problems breaking it loose from the block on the frame. Pointers needed!
This is on a ‘37 with juice brakes.
KenBolton is offline   Reply With Quote
Old 10-21-2021, 04:37 PM   #2
Mart
Mart's Avatar
Default Re: Removing Brake Hose
As this is a non standard application, what is the block you refer to?
Normal type have one fitting with a tube fitting in it and the other side has a block with a banjo bolt into the end of the hose.
What do you have? A picture would help. Have you looked for a banjo bolt?
Mart.
Old 10-21-2021, 05:31 PM   #3
Kube
Kube's Avatar
No pointers really.
Secure the block well with whatever means are necessary. A six point flare wrench is best for the hose. Apply muscle... it'll come loose.
Kube is online now   Reply With Quote
Old 10-21-2021, 05:55 PM   #4
Anteek29
Anteek29's Avatar
Originally Posted by kube View Post
no pointers really.
Secure the block well with whatever means are necessary. A six point flare wrench is best for the hose. Apply muscle... It'll come loose.
Agree
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 10-21-2021, 07:30 PM   #5
paul2748
paul2748's Avatar
If you can slide the correct size box wrench over the loose end, use that. Six point one would be best.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 10-22-2021, 01:43 AM   #6
bobH
deleted... wrong info for this thread... sorry
bobH is offline   Reply With Quote
Old 10-22-2021, 02:01 AM   #7
bbrocksr
Brass block and banjo bolt on the left side, 1/4" tube fitting on the right side.
If it is done like a stock Hydraulic setup,
Bill
Hold the block with an adjustable wrench and break the banjo bolt loose with a box end wrench.
bbrocksr is offline   Reply With Quote
Old 10-22-2021, 07:38 AM   #8
KenBolton
Thanks much!
