Old 10-11-2020, 05:16 PM   #1
JSRTUDOR
JSRTUDOR's Avatar
Default 120 mile round trip
I'm proud to say my non-rebuilt 223ci. 3 on the tree with 87500 miles cruised along at 60 mph for 120 miles (60 each way) with only a little smoke and a few little oil streaks running down the motor! She is screaming at that speed with the 3.89 or so gearing, but she really seamed happy at around 55-60. Lower speeds she's a little grumpier! Can't wait till I get the 272 in it!
JSRTUDOR is offline   Reply With Quote
Old 10-11-2020, 07:12 PM   #2
Daves55Sedan
Daves55Sedan's Avatar
Default Re: 120 mile round trip
You might be able to sell that 223 I-block 6 cyl on fordsix.com.
Daves55Sedan is offline   Reply With Quote
Old 10-11-2020, 08:46 PM   #3
miker98038
miker98038's Avatar
Use the money from selling the six to find an o/d trans (if you don't have one). The 3.89/272/ o/d will work fine on the road.
miker98038 is offline   Reply With Quote
Old 10-12-2020, 04:09 PM   #4
Daves55Sedan
Or keep the manual trans and swap out the old rearend for a '57/58/59, 9" banjo housing rearend where you have many more options for gear ratios available. I had a 2.91:1 ratio that came out of a '58. But even 3.25:1 ratio would be a huge improvement RPM wise. You can additionally convert the 9" to posi-trac if you wanted.
Old 10-12-2020, 07:48 PM   #5
JSRTUDOR
JSRTUDOR's Avatar
I would love an overdrive.
Old 10-12-2020, 08:39 PM   #6
Dobie Gillis
Dobie Gillis's Avatar
They're out there, just keep an eye on eBay and antique/classic car publications. If you have a 6 cylinder or 272 y-block all you need is the T-86. It's the lighter duty (and lighter weight) version of the 2 Borg-Warner OD transmissions, but still plenty stout. The T-85 is the nearly bulletproof heavy duty version but would be overkill behind a small engine.
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
Old 11-22-2020, 07:48 PM   #7
harleyjohn45
harleyjohn45's Avatar
I was told my 56 ford with a 292 has a 330 rear gear. It's a 2 speed automatic, I may change it out to an AOD.
harleyjohn45 is offline   Reply With Quote
Old 11-22-2020, 08:17 PM   #8
paul2748
paul2748's Avatar
A mistake made by new owners of 51-58 Fords with automatic - they are three speeds, not two. In drive, the car starts out in 2nd, but 1st gear is available if you start out in low. Automatic 56's usually had a 3.30 rear gear.
48 Ford Conv
56 Tbird
54 Ford Victoria
