Old 04-19-2020, 10:10 AM   #21
chrs1961815
chrs1961815's Avatar
Default Re: My Engine Project
Purdy and rotorwrench: inside the exhaust manifold where the bolts screw into the holes are blind - there are two bosses that stop the bolts. They are not there anymore.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 04-19-2020, 10:54 AM   #22
Purdy Swoft
Purdy Swoft's Avatar
If the bottom is broken out of either of the 5/16 bolt holes in the exhaust manifold where the intake manifold connects , even if the rest of the threads are still in place , there will more than likely be a slight exhaust leak .
Old 04-19-2020, 11:51 AM   #23
chrs1961815
That is what I thought. Guess I will use another one.
Old 04-20-2020, 10:14 AM   #24
katy
katy's Avatar
Can one not grind the back flat and using a longer bolt put a nut on the bolt?
Old 04-20-2020, 02:30 PM   #25
chrs1961815
Couldn't some sealer similar to muffler stuff be put on the bolt to seal the hole?
Old 04-20-2020, 03:41 PM   #26
Purdy Swoft
The muffler stuff might work . If the manifold isn't sagged , it should be worth working with.
Old 04-20-2020, 06:02 PM   #27
chrs1961815
I think I will give it a try. It is pretty straight and already machined. I just don't want to have to take it off again.
Old 04-21-2020, 10:04 AM   #28
rotorwrench
rotorwrench's Avatar
If a person has enough access, the back side could be brazed up but there may not be enough access to get a torch or brazing rod in there. Someone likely tried to use bolts that were too long to hold those manifolds together.
rotorwrench is online now   Reply With Quote
Old 04-21-2020, 10:35 AM   #29
Purdy Swoft
New exhaust manifolds are pretty reasonably priced . I recently got a new manifold from Brattons . I would recommend a new manifold and not have to wonder if it was going to leak . I
Old 04-21-2020, 11:43 AM   #30
McMimmcs
McMimmcs's Avatar
Thumbs up Re: My Engine Project
I agree, once again money not spent is not aways money saved!
McMimmcs is offline   Reply With Quote
