04-17-2020, 06:14 PM | #1 |
My Engine Project
Some of you might have been following my recent threads detailing my engine build. Today I finished my internal assembly and painted everything.
"The more things change, the more they stay the same." |
04-17-2020, 06:46 PM | #2 |
Re: My Engine Project
You are going to paint it Ford green, correct?
04-17-2020, 07:27 PM | #3 |
It is ford green, it is just the lighting that threw it off.
04-17-2020, 08:42 PM | #4 |
Ford Engine Green actually had some variability. Not necessarily made from "tailings" like the floor boards are reported (actually the floor board drawings specify an actual color) the color supply was sufficiently variable so that presently, restorers are encouraged by the Standards to "match" colors on Ford Engine Green components. The thinking being that all components were typically painted "together" and there shouldn't be any variability between say a valve chamber cover and the engine proper.
Dare I say given today's color technology, the color from a single paint source is probably "beyond close." And better than it was "in the day." Joe K
Shudda kept the horse. |
04-17-2020, 08:51 PM | #5 |
I wonder if it was actually true that they mixed spare paint to create the batch (probably not). I mix my own paint custom based on the MAFCA paint book. I am happy with the way this came out.
04-17-2020, 09:03 PM | #6 |
04-17-2020, 09:20 PM | #7 |
Great job!
04-17-2020, 09:41 PM | #8 |
The shade of green has no effect on how well it goes down the road.
04-17-2020, 11:24 PM | #9 |
Color looks good to me.
04-18-2020, 06:36 AM | #10 |
Well put!!!
04-18-2020, 06:42 AM | #11 |
A question for everybody: I have a nice exhaust manifold but somebody knocked out the bosses behind the bolts, probably after they broke. Is it even usable anymore?
04-18-2020, 06:56 AM | #12 |
Purdy
04-18-2020, 10:25 AM | #13 |
Has that head been welded and/or repaired? It looks a little uneven near the front.
04-18-2020, 10:34 AM | #14 |
That does look good! I'd say job well done.
Southern Missouri '30 Tudor sedan, Original '33 5-Widow Coupe, Henry Steel, Merc Flathead, 50's Hotrod style. |
04-18-2020, 12:26 PM | #15 |
That is a new 6:1 head. I just set it on top of the block to paint it.
04-19-2020, 08:34 AM | #16 |
I've seen some engines painted red
04-19-2020, 09:02 AM | #17 |
The paint looks good , probably better than original . The head and water jacket look like they got painted , color sanded and recoated for a better finish than originally applied when new .
04-19-2020, 09:08 AM | #18 |
04-19-2020, 09:20 AM | #19 |
The manifolds share mounting boss lugs with the intake manifold. They are like a half of a bolt boss with no complete bolt hole. This is a carry over from the model T in a way. If the lugs are not there then neither the exhaust or the intake manifolds will be properly secured to the engine.
04-19-2020, 10:01 AM | #20 |
Bet you can't wait to hear it purrrr!
Thread Tools | |
Display Modes | |
