Old 01-21-2018, 01:28 PM   #1
jwilliams81
jwilliams81's Avatar
Default Installing rear bearing, grease seal, and snap ring video
Hey everyone,
I got around to installing the rear cast iron drums from Randy Gross. After painting them with VCT high temp glass black paint, I installed the greased bearing, grease seal, and snap ring. I made a video showing how I used the Bratton hub seal driver.
Video here:https://youtu.be/ziLpC1qcM7Y
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
Old 01-22-2018, 09:02 AM   #2
Growley bear
Default Re: Installing rear bearing, grease seal, and snap ring video
I use a hub bearing to install the seals, hasn't failed yet.
Growley bear is offline   Reply With Quote
Old 01-22-2018, 09:18 AM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Seems like a SIMPLE task, but if you never did one, it can be a daunting task. Remember, the sharp lip always goes TOWARD the grease.
On LATER Fords, the DIFFERENTIAL PINION seal seems to almost be too BIG & requires a good driver & a Big Hammer to get it in.
"Sometimes" it might dis-lodge the "booster" spring, under the seal LIP, & shortly it will leak, AGAIN! To prevent this, pack the spring area, with wheel bearing grease!
Bill Tipster
"THE ASSISTANT GURU OF STUFF"
Old 01-22-2018, 09:46 AM   #4
jwilliams81
That is a good trick.
Cincinnati, Ohio
Old 01-22-2018, 09:46 AM   #5
jwilliams81
"Sometimes" it might did-lodge the "booster" spring, under the seal LIP, & shortly it will leak, AGAIN! To prevent this, pack the spring area, with wheel bearing grease!
Bill Tipster
Ahh, packing the spring area is a good trick too. Thanks!
Cincinnati, Ohio
Old 01-22-2018, 10:57 AM   #6
BILL WILLIAMSON
JW,
I've been fixin' cars ALL my life & have lurned LOTS of "tricks"--Never know when one "might" help someone. MANY have been lurned from other Folks
Bill W.
