01-07-2018, 12:12 PM | #1 |
Installing Randy Gross Front Brakes/backing plates!
Here is a quick video I made installing the front backing plates:
https://youtu.be/qGjLgN49bUo I am finally getting around to installing the brakes that I had rebuilt by the amazing Randy Gross. I can not say enough how great of a guy he was to talk to on the phone and help answer my questions. Reading all about him and his reputation on this forum has really put me at ease. This is my first Model A and I am really excited to get the brakes done and feel the difference of cast iron drums. I drove 5,000 miles this past year in my first year of ownership and can't wait to put more miles on my Town Sedan.
1931 Murray Town Sedan. Black body with Apple Green pin stripe. 1923 Model T Touring with electric start. Low radiator Cincinnati, Ohio |
01-07-2018, 12:57 PM | #2 | |
Re: Installing Randy Gross Front Brakes/backing plates!
Thanks for the video, enjoyed watching.
01-07-2018, 02:38 PM | #3 |
Two things I forgot to do:
1. I added one pill to the operating pin on each side 2. The castle nuts should go on the outside of the backing plate Those have both been corrected.
01-07-2018, 09:47 PM | #4 |
Nice catch. Watching the video I was wondering about both of those things.
01-07-2018, 09:55 PM | #5 |
First time doing it. At least I didn't have cotter pins in yet
01-07-2018, 09:59 PM | #6 |
01-07-2018, 10:00 PM | #7 |
Yes sir it does. I've read through Les Andrews a couple times for the rears now haha
01-07-2018, 10:13 PM | #8 | |
Please update the info box on the video with these items you mentioned. |
01-07-2018, 10:20 PM | #9 |
Done. Thanks for the idea.
01-08-2018, 04:39 PM | #10 |
All great and lets keep going now..
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
01-08-2018, 05:14 PM | #11 |
Wasn't just a week or so ago that someone had put the castle nuts on the inside, and that kept the drum from seating? At first it was thought maybe there was something wrong about the bearings or races.
01-09-2018, 03:27 PM | #12 |
I could see that possibly being a problem. Fortunately, Mark Maron pointed out my mistakes before I had the cotter pins in the bolts. It only took 10 minutes to fix the bolts on each side.
01-09-2018, 04:44 PM | #13 |
What is the purpose of adding the "pill"? I would assume that with new everything that a pill would not be necessary.
01-09-2018, 04:59 PM | #14 |
The brake actuating assembly was not new. So a pill inserted on a new pin should help take up any wear on the actuating assembly. I should get the full 15 degree forward lean that is wanted.
01-09-2018, 07:15 PM | #15 |
So, its like Viagra?
01-09-2018, 08:02 PM | #16 |
Yes! Only it should last longer than 4 hours :-)
01-09-2018, 08:25 PM | #17 |
Thank you for sharing that video. That new backing plate looked so neat when you first installed it. I think that I would have had to just sit back and admire it for a few minutes before doing anything else.
Thanks again for sharing, Mike |
01-09-2018, 09:02 PM | #18 |
Does the "pill" go on the top of the rod or on the bottom?
01-10-2018, 04:29 AM | #19 |
Pill goes in the bottom.
Jeff
Let's let pylons, be pylons! |
01-10-2018, 08:42 AM | #20 |
Yep, the pill goes on the bottom. It's just a concave washer... Looks like a small metal contact lens.
